Sound Dampner/Polyfill. Both?
Old Dec 8, 2018 | 01:58 PM
smlosches@yahoo.com's Avatar
smlosches@yahoo.com
Default Sound Dampner/Polyfill. Both?
I have installed sound dampner inside my outer fairing. Also, have polyfill wrapped around rear of speakers.
I know there are different opinions on this subject. So lets hear them.
Do you get a different benefit from each? Dampner help with fairing vibration? While polyfill tricks speaker into thinking it is in a larger space?
Only need one or the other?
Old Dec 8, 2018 | 02:08 PM
Newharleylover's Avatar
Newharleylover
I'm absolutely no expert on the subject but when UltraNutz was kicking around here one of his suggestions was polyfill. What my speakers did before that was the sound was bouncing around inside the fairing producing undesirable results. After I polyfilled around them it cured that. It made for a better sounding bass for sure.
Old Dec 8, 2018 | 02:22 PM
MURPHCC1's Avatar
MURPHCC1
Yea I use the poly fill as well........much better sound!!
Old Dec 8, 2018 | 03:46 PM
Tailwind's Avatar
Tailwind
Damn near every different speaker will respond in a different manner. The dynamat is without question a huge improvement for the fairing "speaker enclosure" but the benefit from poly will vary a bit.
T
Old Dec 8, 2018 | 06:58 PM
marcodarq's Avatar
marcodarq
the 2 different materials do 2 different things. one is a sound damper and one creates "an Illusion" for the speaker's suspension. I would think that a combo of both work give the best results. on the non rushmore bikes i've had very good luck using polyfill packed around the speaker. I'm probably going to put some dynomat in this weekend, so i'll post up the results if it's anything to write home about.
m
Old Nov 14, 2019 | 07:53 AM
Red8972's Avatar
Red8972
Default Polyfill
Ok what is the reasoning to wrap the back of speakers with polyfill ? What does it change ? I have to much distortion will this help ?
Old Nov 14, 2019 | 07:58 AM
FrenchieM's Avatar
FrenchieM
It will not help distortion that I am aware of. You need to properly set your gains on your amp to start.
Old Nov 14, 2019 | 10:17 AM
Red8972's Avatar
Red8972
Default amp
What’s the correct way to set them I just think I need better speakers witch I plan to do soon !!
i got J&m rokkers the blue ones
Old Nov 14, 2019 | 10:24 AM
FrenchieM's Avatar
FrenchieM
Look at the sticky on gain setting at top of this thread. That’s one way or some will tell you to
use your ears. I would suggest some better speakers as well
Old Nov 14, 2019 | 10:41 AM
SBates08's Avatar
SBates08
What does your system consist of?
