Anyone try this amp?
https://www.massiveaudio.com/product...nnel-amplifier
FEATURES:
- Extreme Power in a Mini Compact Footprint
- Conformal Coated PC Board to Resist Moisture, Dust and Extreme Heat
- 1 Ohm Stable Design (BL1, BL3, BL4)
- 4 Layers PCB design with SMD parts
- Built-in Noise Reduction Circuitry
- Full MOSFET with High Grade Switching Devices
- Bluetooth Audio Streaming with (Optional) UBT1 Dongle (BLX2, BLX44, BLX48, BLX5)
- Built-in Auto Sensing Turn On Function (Hi-Inputs)
- 12V Remote Output for External Devices (Hi-Inputs)
- -3 ~ + 12DB Variable Bass Boost 40 Hz - 100 Hz (BL1, BL3, BL4)
- -6 ~ + 12DB Variable Bass Boost 40 Hz - 200 Hz (BLx5)
- Advanced 5 Way Protection Circuitry
- RCLX ~ Railcap Booster (Optional)
- World Wide Standards Compliant (RoHS, E-Mark, CTA-2006, CE)
Peak Output Power @ 14.4V 800W x 2 Max1 Ohm RMS n/a
2 Ohm RMS 400W x 4
4 Ohm RMS 200W x 4
4 Ohm Bridged 800W x 2
Input Level 0.2~9.0v
Freq. Response 10Hz~25KHz
THD at 4 Ohm Load 30%
Rated Power<0.03%
S/N Ratio> 90dB
Bass Boost N/A
Minimum Load 2 Ohm Stereo
Gain Remote n/a
Dimension1.6"H x 4.25"W x 10.75"L
Looks like some good power in a small package, and can be found for $299.
The 5 channel looks interesting too. https://www.massiveaudio.com/product...nnel-amplifier
240X4 + 600X1 @ 2 Ohm
120X4 + 300X1 @ 4 Ohm
for $349.95
The specs are at 14.4 volts.
here is a pic installed:
and a video of (4) 6.5's off front channels and (2) 10's off the rear channels
https://www.facebook.com/100007497916191/videos/2152614941665082/
I couldn't post it as a link, so you'll have to copy and paste it in your browser.
Hmm, its on a page you have to join, that's probably why it's blocked.
https://www.facebook.com/groups/287231571930713/
