Run speakers off 2 pin charger pig tail.
Old 01-09-2019, 12:11 AM
drinktothat421's Avatar
drinktothat421
drinktothat421 is offline
Default Run speakers off 2 pin charger pig tail.
Could i use the 2 pin rather then wiring to the rerminals? Look at the cheap boss rebel speaker and amp. Use the 2 pin i could disconect it as needed.
Old 01-11-2019, 12:20 PM
kevinb62's Avatar
kevinb62
kevinb62 is offline
That’s how I have my wires ran to my saddlebags .I haven’t finished the install, still waiting on paint on new stretched bags and lids. Everything worked great during the mock-up.
Old 01-11-2019, 04:15 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
it depends on how much current your rig is going to draw. the wires for charging harnesses typically are not rated to handle large draws. 10-15 amps max. you need to know what it is going to draw and fuse it accordingly. If the base wire is not rated for the amp draw, then you will either have to use a connector harness that is properly rated, or wire it to the battery.
m
Old 01-12-2019, 11:49 PM
slodsm's Avatar
slodsm
slodsm is offline
Look into XT-60 or XT90 connectors on eBay. I have played around with RC racing for 20+ years and can vouch for an xt60 taking over 100 amps of current with no issues. It’s small but freakin stout. The XT90 I’d look at if you don’t have ridiculous soldering skills as it places to connect it are larger and easier to put together.
I use tiny XT30’s as quick disconnects for my lowers up front so I can unhook and remove them quickly if I ever lose my mind and want to ride completely naked.
Old 01-14-2019, 08:24 PM
drinktothat421
m
the amp harrness has a 5amp fuse in it. So im thinking it abouldnt be an issue.
Old 01-15-2019, 08:41 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
I have gotten those plug harnesses with 12 gauge wire before to use as charger extensions. I would think 12 gauge would be plenty for speaker wire but I don't know the exact makeup of the wire.
drinktothat421
Electrical/Lighting/Alarm
01-09-2019 03:15 PM
Wheelie Ripper
Audio Systems
07-11-2018 08:08 AM
big- mike
Audio Systems
01-17-2018 11:29 AM
bobbyjoes
Audio Systems
18
04-02-2017 08:02 PM
Strait
Audio Systems
04-05-2013 04:27 PM
Quick Reply: Run speakers off 2 pin charger pig tail.
