Installing RF Rear Kit
Old Apr 8, 2019 | 11:21 AM
gunslingersnation's Avatar
gunslingersnation
Default Installing RF Rear Kit
Those of you that have done this, two questions... Did you use a dremmel or jigsaw to cut the lids? Are there instructions on the quick connect locations. None of the videos show the back end wiring, and I've seen a mix of dremmel and jigsaw cutting.
Old Apr 8, 2019 | 11:26 AM
Juice's Avatar
Juice
Jig saw works fine, Use the correct size drill bits though for your pilot holes. Use a thinner scrolling blade with the jig saw and take your time. I think it calls for a 3/4 in hole saw for the grommet. I would just position the hole for the wire towards the front may be a tad bit lower and rearward of the front bag pin hole.
Juice
Old Apr 8, 2019 | 11:38 AM
travelingypsye's Avatar
travelingypsye
Juice
Yes sir 3/4 is the hole size for the wire grommet. Very important to use a thin scrolling blade and take your time.
Old Apr 8, 2019 | 12:00 PM
gunslingersnation
Will this work? I'm not a jig saw master.
Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
Bosch 4 in. 10 TPI High Carbon Steel T-Shank Jig Saw Blade for Cutting PVC without Melting (3-Pack)
https://www.homedepot.com/p/Bosch-4-...102H/203451221
Old Apr 8, 2019 | 02:04 PM
mikes300's Avatar
mikes300
everyone is saying scroll blades, they are skinny like these, used for cutting tight radius turns
https://www.homedepot.com/p/Bosch-3-...01AO/100083111
Old Apr 8, 2019 | 05:09 PM
Tailwind's Avatar
Tailwind
A step bit works very well for grommet holes.
T
Old Apr 8, 2019 | 09:23 PM
Mattburke1028's Avatar
Mattburke1028
6th Gear
Jig saw, just installed this kit last weekend. Very simple just make sure you tape the lids up good. And make sure to put your latches back on before you put the grills and speakers in if you've got the one touch latches.
DR.M3TAL
Jun 1, 2017 10:36 AM
bobbyjoes
Audio Systems
Mar 16, 2017 07:59 PM
rpmpit
May 20, 2013 01:49 PM
Ben E
Apr 12, 2012 11:24 AM
Dumass
May 12, 2008 10:52 PM
