Will a Stinger SPX700X4 push 6 speakers?
Old Apr 26, 2019 | 12:27 PM
SOFTPETER's Avatar
SOFTPETER
Originally Posted by Hoyt 1911A1
You say line level, but I assume you mean speaker level since you said between the speakers and amp. If so wouldn't that jack with the impedance of the load when you tried to adjust it? That's what a level control is, just a variable resistor.
Hello, correct in line with the speakers. No it won't interfere with the impedance. I will say on the channels he plans on doing this to I would make sure 8ohm speakers are used so once all 4 speakers are connected
the amp will see a 2ohm load on ch 3/4 etc.
Old Apr 26, 2019 | 12:29 PM
SBates08's Avatar
SBates08
If you are running the same 4 speakers up front, get the SS pn4.1000 and run the front 2 sets in parallel. That would leave the rear channels open on the amp to push the lids.
Old Apr 26, 2019 | 12:49 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I think Bates has posted the most economical high performance option so far. I have run that amp in the configuration he mentioned before and it performed well. The problem I had was my four speakers in parallel were so far apart that I couldn't balance them out. With the front four speakers on your bike being so close together the SS amp sounds like something I would try.
If later on you find that you can't hear your two 6.5s pointing inwards as well as you like then when money allows get a B52 for your rears and run the four 6.5s on the four independent channels of the SS. I did something similar with my setup and really liked the change.
Old Apr 26, 2019 | 03:33 PM
Tailwind's Avatar
Tailwind
OP, check the measurement on the Massive Audio BLX48 as that sucker has lots of watts and can be had pretty cheap.
Parallel the front on 1&2 and rear on 3/4.
It's just a matter of if that sucker will fit.
T
Old Apr 26, 2019 | 05:26 PM
Biggzed's Avatar
Biggzed
You may have to cut on the radio mount to get the SS above the radio. I ran one in my 07 Road Glide, but I mounted it behind the glove boxes. You don't have that option with your speakers stuck in there. It's gonna be tight, but I bet it would work with a little trimming on that mount.
Zach
Originally Posted by Quickrunner1
Is the SS PN4.1000d much bigger size wise than a rockford pbr 300x4 ? I know the CVb54 &52 are about the same and would fit but sounds like the SS is more powerfull. How does the SS stack up size wise and power wise against the Stinger I mentioned? Sounds like if I want to keep 6 speakers I am going to have to stay with 2 amps.
Old Apr 26, 2019 | 07:06 PM
Ndfastln's Avatar
Ndfastln
I had one mounted on top of an aftermarket radio on a 2008 RG. It fit with no problems. I second that Massive Audio BLX 48 as a good option, if you can find one. I'm trying to get hooked up with a distributor for them now as many places are sold out.
Old Apr 26, 2019 | 08:19 PM
Tailwind's Avatar
Tailwind
That's gonna be a very nice damn amp for some folks brother!!! Tons of power without a huge sticker shock, yet.
T
painey
Audio Systems
14
May 8, 2019 04:41 PM
papejr
Audio Systems
Mar 12, 2019 09:34 AM
JHC210
Jul 22, 2015 10:28 PM
CorbinT
Audio Systems
Jun 20, 2013 03:57 PM
joeybedford
Apr 17, 2012 07:41 AM
