Amp mounting on BT bracket
Old Jul 20, 2019 | 10:31 PM
D_Cantelow's Avatar
D_Cantelow
Default Amp mounting on BT bracket
What is the ticket to get the fairing to fit with this mounted on the right side bracket? 600.1 on the left side has plenty of room. It can slide deeper past the magnet. Rubbing where my fingers are. I put it at a slant next to cig lighter level and still rubbed. Can I heat and mold that corner of the amp?
Old Jul 20, 2019 | 11:49 PM
Tailwind's Avatar
Tailwind
No ticket on the brake side of the bracket brother. That additional cubby on the bracket itself is far enuff outward that ur just not gonna get that amp to fit there as it hits the dramatic change in the fairing ascetics in that area. Try the clutch dude cubby.
T
Old Jul 21, 2019 | 12:13 AM
D_Cantelow's Avatar
D_Cantelow
Cubby has dsp crammed in there. Any other option for inside faring?
Old Jul 21, 2019 | 01:32 AM
IArider1's Avatar
IArider1
are you able to hang it in the front off the front of the amp tray?
Old Jul 21, 2019 | 02:23 AM
sponger's Avatar
sponger
If u arent using using the cigarette lighter, get a plug and that will allow the amp slide further down the bracket to get u your space.
Old Jul 21, 2019 | 08:59 AM
GunslingersNation1's Avatar
GunslingersNation1
Have you tried the clutch side?
Old Jul 21, 2019 | 09:11 AM
D_Cantelow's Avatar
D_Cantelow
Clutch side has another amp. I tried next the cig lighter, and it still wasnt low enough.
Old Jul 21, 2019 | 09:28 AM
Tailwind's Avatar
Tailwind
What is on the laundry list of things ur trying to stuff under the hood?
T
Old Jul 21, 2019 | 09:30 AM
D_Cantelow's Avatar
D_Cantelow
T
Jl600/6 on modified stock tray, sd 600.1 on clutch side bracket. DD dsi-2 in cubby hole where cb was. Needing to get the sd 250.2 a home.
Old Jul 21, 2019 | 09:33 AM
Tailwind's Avatar
Tailwind
Stock Boom HU?
T
