Speaker popping
Old Jul 30, 2019 | 04:33 PM
GunslingersNation1's Avatar
GunslingersNation1
Default Speaker popping
Getting everything dialed in, I had my eq on the woofers pushed up in the way explained in the AHB article. The left sounded fine, the right started to pop on big notes. I thought it was hitting the grill, so I changed them to the factory Pioneer grills. I notice at high volumes it's still doing it on the right. I flattened the eq and that helped a lot. I turned the subwoofer channel down -4 and they got rid of almost all of it. Is this a grill issue or speaker issue? Is it possible I have tightened the grills to the point that it doesn't allow the cone proper movement?
Old Jul 30, 2019 | 04:51 PM
FrenchieM's Avatar
FrenchieM
Take the grill off and see if it does it.
Old Jul 30, 2019 | 04:56 PM
GunslingersNation1
I'll do that. I just have to drive around to test because I'm so loud now, the neighbors get pissed.
Old Jul 30, 2019 | 05:14 PM
GunslingersNation1
Grills off, all other 6 speakers muted, high volume (25 or so) still pops on big notes
Old Jul 30, 2019 | 05:26 PM
Babyboy's Avatar
Babyboy
What speakers are you running on the SUB output???
Sounds like you may have the speakers playing in the frequency range.
Old Jul 30, 2019 | 05:30 PM
InthewindMN's Avatar
InthewindMN
What freq range are they playing?
Old Jul 30, 2019 | 06:19 PM
GunslingersNation1
This pair is a set of Pioneer tsm800pro. running about 200 watts each. High pass at 63hz.
Old Jul 30, 2019 | 06:40 PM
SBates08's Avatar
SBates08
I'd bump them up to at least 75hz. My JL 880's claim down to 30hz but below 70hz at 200 watts they will stumble.
Old Jul 30, 2019 | 06:49 PM
GunslingersNation1
I can do that. I did try that a few days ago, however had the eq jumped up from 80-125. I'll try it flat and see. If not, thank the lord for amazon returns.
Old Jul 30, 2019 | 09:52 PM
FrenchieM's Avatar
FrenchieM
I’d agree with SBates that too low for them speaks. My PRV are 65 but they do well there not sure
those pioneers are up to the task that low
