Bridged Gain Settings
Old Aug 18, 2019 | 06:14 PM
GunslingersNation1's Avatar
GunslingersNation1
Default Bridged Gain Settings
I ready the sticky post, but please double check me. When setting gains for a 4ohm bridge, using a multimeter, I use the positive and negative leads in the appropriate bridge location (L+ R-), then use the voltage calculator for the proper bridged wattage. Then adjust the gain to the proper voltage for the total output.
Example, I am wiring the two rears to a 2 channel amp. They are 8 ohm speakers, so it's a 4 ohm load in parallel. 4 ohms, 400 watts means I turn the gain to 40 volts, exactly the way I would do it unabridged, correct?
Old Aug 20, 2019 | 12:56 PM
M M Alexander's Avatar
M M Alexander
400 x 4 = 1600
1600 = 40
Measure the output at rails set gain to 40 (Using a 50Hz test tone from a clean signal)
roussfam
Audio Systems
31
Sep 3, 2019 07:37 AM
Mikerunsjax
Audio Systems
Feb 25, 2018 10:10 AM
Weeboy1
Audio Systems
Jun 13, 2016 12:04 AM
slyedog
Audio Systems
May 9, 2016 09:45 AM
pp6000v2
Audio Systems
Apr 14, 2014 12:51 PM
