Ground loop noise
Old Oct 13, 2019 | 10:21 AM
DoubleD8's Avatar
DoubleD8
Default Ground loop noise
Just installed a Kicker PXA300.4 amp and Polk MM652 speakers and BT 355 line leveler in fairing of a 2016 Street Glide Special. Using stock head unit. I have EQ on head unit set at 0. With gains turned up past about 1/4 on amp I'm getting a humming noise. Thinking it is a ground loop issue. I ran the power and ground wires for the amp to the battery. Has anyone had this issue? What's the best way to solve this?
Old Oct 13, 2019 | 04:59 PM
Tailwind's Avatar
Tailwind
Bad RCA or RCA interference.
T
Old Oct 13, 2019 | 06:42 PM
Biggzed's Avatar
Biggzed
As Tailwind posted, try jiggling the RCA's and see if the noise changes. Make sure the connectors are as separated as they can be and the connections are tight.
If the RCA's are not the problem, you can try a pair of PAC SNI-1. They did the trick for me.
Zach
Old Oct 14, 2019 | 05:31 AM
DoubleD8's Avatar
DoubleD8
Zach
Yea I have a pair of PAC SNI-1 on the way. Connectors are all tight. Sounds like filters are the solution. Thanks
Loujr28
Jul 22, 2019 10:28 PM
roussfam
Audio Systems
25
Sep 16, 2018 05:33 PM
Kokes58
Audio Systems
11
Oct 13, 2014 09:53 PM
BlessedHellride
Audio Systems
Mar 22, 2014 08:19 AM
customsoftail200
Audio Systems
Mar 7, 2013 09:13 PM
