Soundstream pn4100d speaker suggestions
Old Nov 8, 2019 | 12:50 PM
Fireball Jack's Avatar
Fireball Jack
I would go with the Mmats 601.cx and just dont spray em. I had to use a adapter to make the Mmats fit in the tour pak. They sound a lot better than the Kappa's and about the same price.I used these grills for the lowers. https://www.ebay.com/itm/6-5-Saddleb...8/132134562966
Old Nov 8, 2019 | 02:33 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I have had good luck with the Analog Designs AD CX621s in my tour pak pods. They fit with only a 1/4" spacer and sound good without being too bright. They are water resistant out of the box.
ADCX622
Old Nov 8, 2019 | 02:55 PM
SBates08's Avatar
SBates08
Here's the biggest issue with paralleling the lowers with the removable tourpack....once you parallel them your amp sees a 2ohm load and your amp gains are set accordingly. Once you remove the tourpack, your amp is now seeing a 4ohm load for the rear channels and your gains will not be correct.
I would suggest adding a 2 channel amp or a small micro 4 channel to run the tourpack.
Old Nov 8, 2019 | 03:15 PM
FrenchieM's Avatar
FrenchieM
Yeah that ☝️
Old Nov 8, 2019 | 05:38 PM
Bluesman280's Avatar
Bluesman280
Mmats 601.cx in fairing with speaker adapters, Mmats will also fit in lowers, both sets run off the SS amp. Pick up a Hogtunes amp bracket and mount a NVX Vadm4 amp bridged to your tour pack speakers. Mmats work good there as well but you need a speaker adapter, or you could use the Polk 6.5" MM series as it fits without an adapter.
Old Nov 8, 2019 | 05:43 PM
Bluesman280
Would he be able to run Mmats in the fairing and lowers off the front channel of that SS at 2ohm, and the tour pack speakers off the rear channel in 4ohm?
Old Nov 8, 2019 | 09:57 PM
SBates08's Avatar
SBates08
I wouldn't want to but I'd do it that way before I did the other scenario.
Old Nov 8, 2019 | 10:06 PM
Tailwind's Avatar
Tailwind
Or get a PAC LC-1 which may get u the required voltage regulation without taking the hood off. Worth a try for $10?
T
Old Nov 9, 2019 | 10:48 AM
emperor wurm's Avatar
emperor wurm
Great info, thanks for all the input!
Old Nov 9, 2019 | 11:09 AM
Bluesman280
Yep, I always prefer someway of gain adjustment, or someway of being able to balance out levels and adjust x-over frequency on each pair of speakers, thus I usually prefer to add the extra amp.
Figured if there was any limitations on budget, he could save on the extra amp cost for now as long as he kept the lowers and fairing speakers the same or fairly compatable.
