DSR1 Setup?
Old Nov 11, 2019 | 07:45 PM
abadv8's Avatar
abadv8
Default DSR1 Setup?
I have my DSR installed, but the firmware is v1.2.0.0. I downloaded the iDatalink desktop client, but cannot get it to recognize my DSP. Anyone else run into this?
Old Nov 11, 2019 | 08:48 PM
abadv8's Avatar
abadv8
After some serious screwing around, I finally got the thing to update. It's still dropping Bluetooth constantly. Basically rendering this thing completely useless. I've got a ticket in with Rockford. Has anyone else experienced this?
Old Nov 12, 2019 | 08:59 PM
sponger's Avatar
sponger
Make sure location is turned on as well.
Old Nov 12, 2019 | 09:11 PM
arlington's Avatar
arlington
A friend just got rid of his for the same reason, he actually bought a IPhone, because he was told the dsr 1 worked better with the Iphone. Unfortunaltely same issue, he sold it and bought a Arc Psm, problem solved.
Old Nov 13, 2019 | 06:33 PM
Biggzed's Avatar
Biggzed
My DSR1 was a little troublesome with BT connection as well. What I found to work best is to shut the app down after I was done. That seemed to make connection the next time I launched the app pretty reliable.
Zach
Old Nov 15, 2019 | 10:45 AM
abadv8's Avatar
abadv8
For anyone that has issues with the connection, the firmware & software is absolutely key. I remembered doing an iDatalink install as part of a security and BCM interface for a remote start system years ago and having basically the same challenges (minus Bluetooth). iDatalink will either make the device work, or completely cripple it.
I wound up updating the firmware, the Bluetooth "driver"(?), and then having to flash the universal settings from Maestro. Everything works pretty good now. There doesn't seem to be much of a difference in connection / performance between an iPhone or an Android phone. Overall, I'm pretty happy with the results.
I also used the setup file from AHB, but wound up taking the low and high frequencies down a couple of dB. And, I'm not exactly sure how the Punch EQ functions. I assumed it was like loudness on some aftermarket head units, but that doesn't seem to be the case.
Next up, I'd like to see if I can find some 6.5's that have a little more tolerance for the lower frequencies. Realistically, probably just need to go hear some other setups...
rooti
Sep 12, 2016 12:12 PM
1badbagger
Gear and Other Items For Sale
Feb 5, 2010 08:07 PM
Scout
Jul 22, 2009 07:50 AM
Trock
Aug 12, 2007 12:05 AM
Ace17
General Topics/Tech Tips
23
Feb 15, 2005 08:18 AM
