You can almost always benefit from a DSP, but it's not required with full range speakers. There are many speakers in the Euphoria line, some are full range some are not. Which ones were you interested in? The top of the line EX6NCD's come with crossovers so no DSP is needed, but take a lot of power. The EX6NCX's are a full range coax and also does not need a DSP. There are amps capable of powering all 6 speakers easily enough. A Massive Audio TX48 will do it without breaking the bank and fit in the RG fairing on top of the headlight.
