nvx amp
Old Dec 15, 2019 | 06:56 PM
marshallb's Avatar
marshallb
Two of them on two PRVs may be overkill. Just throwing parts at this isn't going to get you to the finish line. Step back and consider the whole pie for a minute.
Old Dec 15, 2019 | 07:01 PM
Ron D 33's Avatar
Ron D 33
You're right, I never said he needed two of them. I know what the amp is capable of and what I've experienced.
Old Dec 15, 2019 | 07:16 PM
marshallb's Avatar
marshallb
Originally Posted by c_mancuyas8
What do you have them on? I'm thinking about bridging it to 2 prvs that need close to 500w
Sorry Ron I misread this post.
I stand by my statement about pumping the brakes. OP has like 3 threads and seems a little rushed.
Old Dec 15, 2019 | 07:44 PM
c_mancuyas8's Avatar
c_mancuyas8
​​​​​​​Reason for another is although there was good discussion I had asked for amp suggestions only got one and it was from a vendor. I'm happy with the speakers I have only ones I want to change are the DB es9's. The diamond is a great amp I plan to keep it and get some mid bass drivers to replace the es9 and run them off the channel I have the prvs on. I posted this because I need a single amp powerful enough to push the prvs.
Old Dec 15, 2019 | 09:18 PM
langwilliams's Avatar
langwilliams
I have one an it interfered with my FM. others have said it isn't a problem. I still use the radio now an then an like having the option to use it. It sounded great pushing my Hertz speakers playing music off a usb stick. I'm selling it with a set of speakers an a line leveler got a member on here already thinking about it. I installed a Sony ax5000 an a Sound Digital evo 400.2. I got the interference with both the stock 4.3 an the Sony radio.
Old Dec 15, 2019 | 09:30 PM
marshallb's Avatar
marshallb
Have you decided on a DSP?
Old Dec 16, 2019 | 06:02 AM
c_mancuyas8
Pretty sure I'm going to use the Dayton I've heard nothing but good about it
Old Dec 16, 2019 | 08:42 AM
marshallb's Avatar
marshallb
Are the channels able to be unlinked on the Dayton?
What are you considering speaker wise for the fairing?
Old Dec 16, 2019 | 08:56 AM
Ndfastln's Avatar
Ndfastln
Yes you can unlink channels on the Dayton. 8 full channels for use.
Old Dec 16, 2019 | 12:37 PM
c_mancuyas8
I've had the SD 800.4 in the back of my mind for a while. I'm going to go with that bc I know without a doubt it'll be enough and going to pair faital 6rs140 with the prv for front stage prv in the lowers.
