Audio Upgrades
Old Feb 1, 2020 | 12:00 PM
Mark Alsip's Avatar
Mark Alsip
Stage II
Default Audio Upgrades
I have an 05 Ultra Classic which I was hesitating to upgrade audio because of age of machine and mileage on the stator. Well I had to replace the stator and now it's time to be able to enjoy my tunes.
Right now it has a factory radio, not the correct one as the rear speakers don't work and now Intercom or CB. So the question becomes where do I start?
I only plan to have this machine for 1 maybe 2 more seasons so I don't need to go over the top.
  • Looking for louder at highway speeds
  • Clearer audio with some bass (I basically turn bass all the way down to hear at highway speed)
  • Better reception locally for Radio
  • Great Bluetooth audio (I currently use an MPOW Bluetooth to Aux adapter which I have mounted for left index finger ability to skip songs)
  • Hand controls to work
  • I am going to add lower fairing speakers and not use the rear speakers (Is there a better lower speaker for more full sound)?
Let me know your thoughts and experiences.
Old Feb 1, 2020 | 02:09 PM
travelingypsye's Avatar
travelingypsye
You need bang for the buck that can be heard at speed. I suggest an aftermarket hu (something with a white background and blue tooth available. I also suggest 4 kappa's and a nvx vadm4 amp. That will set you back less than $500 for a complete new setup. Not the best SQ but 200% better than what you have now. You could spend a bit more for a mmats pa601cx speakers and a stinger amp but you will want to take that out when you get rid of the bike. lol.
Metra or scosche hand control interface and an amp wire harness will be needed also.
Old Feb 1, 2020 | 02:14 PM
Mark Alsip's Avatar
Mark Alsip
Stage II
Can you elaborate on the hu? If I include a head unit with handle bar controls I don't all new set up for under $500.
What is the preferred vendor for the Kappas and nvx vadm4 to support this site?
Thanks
Old Feb 1, 2020 | 02:16 PM
Bluesman280's Avatar
Bluesman280
Hey Mark, I have an 05 Ultra that I have upgraded the audio on. Not sure on your budget but I can toss you a few ideas.
i run a Sony marine HU. The one I have is the Sony MEX 70BT which is a few years old but has held up well. I used a Biketronics mounting bracket for the HU and the Biketronics handle bar control module which is a little pricey, but had worked flawless for the last 4 years. I also bought a friction fit rain cover that I only use in heavy rain or at the car wash.
One of the better 4 channel amp choices out there for a reasonable price has been the Stinger 700 SPX. It can be mounted right on the head unit with some Velcro. It's a great sounding amp with built in gain and x-over adjustments. There has been some recent deals floating around on this amp. Hopefully you can find a bargain.
You will need some speaker adapters in the fairing.
Amazon Amazon
Speakers: lots of choices. I recommend the Mmats 601.cx. Great riders speaker. It will easily fit in the fairing with those adapters.
The can also be used in the rear speaker pods but you will also need adapters there as well. I used the Vtwin speaker adapters. They are a little pricey, but work good and look great.
This may be a little more Oney than you are looking to spend but it definitely makes for an enjoyable system you can easily hear out on the highway.
if you want to save a few bucks, just do your front speakers now and maybe add some budget speakers to the rear pods to add a little fill. There are a few 6.5" speakers that will fit in the rear pods without adapters, that won't be as good as a set of Mmats back there, but would be better than nothing.
Old Feb 1, 2020 | 02:21 PM
travelingypsye
Thanks
Check the for sale section here for what you need as many of us regulars have stuff for sale there all the time. Do your research for the amp and speakers. I am not sure just who is and is and as not a preferred vendor here as I have gotten in trouble for not referring to said sponsored vendors. Hopefully others will chime in with vendors here.
WindowMan
EVO
Feb 16, 2015 10:57 AM
AmericanHB
Audio Systems
Dec 10, 2014 09:12 PM
kevinckb3
Apr 21, 2014 03:16 PM
Bonzaiii
Audio Systems
Oct 22, 2012 07:19 AM
marco
Oct 31, 2006 08:08 PM
