DD DSI-2 input sensitivity
Old Feb 14, 2020 | 06:57 AM
marshallb's Avatar
marshallb
Default DD DSI-2 input sensitivity
I've been running my DSI-2 with the stock HU and 8/2 flash for a year using the speaker level input. Things seem fine, but I got to looking at the specs and it raised a question. The high level input sensitivity is 7V-14V. Low level is 855mV-1.6V. I have it on good authority that the Boom HU is around 3V output with the 8/2 flash. This bugs me. I'm thinking of adding an LOC to drop the voltage and see if it falls in the low input range. Am I over thinking this?
Old Feb 14, 2020 | 07:07 AM
InthewindMN's Avatar
InthewindMN
You’re overthinking it. Keep your output close to input voltage and go.
What would be the benefit to dropping input voltage?
Old Feb 14, 2020 | 01:03 PM
Babyboy's Avatar
Babyboy
I had the same concern right after the DSI-2 came out.
I called DD and talked to the tech support about the voltage difference on the inputs and was told it was a typo with the voltage gap between low level and high level inputs.
The tech said to hook it up and set it.
That is a legit question but as ITW mentioned dont over think it
ArtVandelay
Electrical/Lighting/Alarm
Feb 28, 2018 05:29 PM
Mach1FB
Audio Systems
Sep 2, 2017 10:32 PM
Luis GodzirahGang Nieves
Aug 29, 2017 08:30 PM
fournierrandy
Audio Systems
Jun 30, 2015 08:36 PM
MyBeerBelly
Aug 10, 2010 10:41 PM
