Pissed
Old Feb 29, 2020 | 01:17 PM
sbeamer's Avatar
sbeamer
Angry Pissed
So I have my NEW amp installed. This is the 2nd one. It lasted less than 1 hour. It is wired according to the diagram that was sent with it. I bought the $ 245 wiring harness from the same place I bought the amp from. It is a Plug N Play harness. I did it this way so it almost couldn't be wired wrong. After I get it all together, and the gains and freqs set, everything sounds great, I put the fairing back on and maybe 20 minutes later, it's ****. I haven't even turned it past 1/2 volume. It's a Mmats MD 4110. Plug ed into a stock H-D 6.5 hu.
What can I do to check if its the amp ?
Old Feb 29, 2020 | 01:23 PM
Outkast6991's Avatar
Outkast6991
hows it wired? What harness are we talking about? What exactly does “ it’s ****” mean?
Old Feb 29, 2020 | 01:40 PM
SBates08's Avatar
SBates08
Do you have a line leveler in play or a DSP?
Old Feb 29, 2020 | 02:20 PM
sbeamer's Avatar
sbeamer
Well, I don't have the diagram in front of me, but The + and - are direct to the bat. They are 8ga. All the connections at the amp are push in with a positive lock on them. The other end of each cable is color coded with RCA connectors. Those plug into a LOC, which, on the other side, has the wires that go to the speakers and the amp itself. There isn't a DSP or line leveler installed. Mmats said not to put one in. Keep in mind, it sounded awesome for a little while. The first amp lasted about 10 days. The sound turns to crap meaning, it looses power output, sometimes temporarily, most of the time it sounds scratchy and fuzzy. Very tinny and no bottom at all.
I just unplugged the amp, and ran the speakers without and they sound good. So I don't think the speakers are bad.
This is that LOC
Old Feb 29, 2020 | 03:27 PM
InthewindMN's Avatar
InthewindMN
What are the settings on the amp set at?
where is the remote turn on hooked to?
Old Feb 29, 2020 | 06:32 PM
sbeamer's Avatar
sbeamer
The gains are about 10:00 and the freq. are around 12 to 1
The remote turn on is connected to the blue wire on the LOC
Old Feb 29, 2020 | 06:38 PM
Outkast6991
can you replicate it acting up just sitting in the garage playing?
Old Feb 29, 2020 | 06:45 PM
sbeamer's Avatar
sbeamer
Once it starts to do (what ever it is), it is pretty much constant. rarely does it sound good again.
Old Feb 29, 2020 | 06:47 PM
sbeamer's Avatar
sbeamer
Is there a process an amateur can do to test the output of the amp? Will this even show up on a meter of some sort ?
Old Feb 29, 2020 | 06:48 PM
Outkast6991
so right now it still sounds bad? Can you wiggle the rca’s/loc and get a change in sound?
