Pissed
Old Mar 1, 2020 | 03:23 PM
Outkast6991's Avatar
Outkast6991
Originally Posted by sbeamer
I guess I would like the fade, but not a must. But I would still use the 2nd BT355, correct? Will it still be stereo ?
If the MD4110 puts out 110 wpc, won't I only be getting 110 divided by 2 then ?
mid you are ok without the fade just run the 355 to the front rca inputs and set the 2/4channel switch to 2. Amp still puts out full power
Old Mar 1, 2020 | 06:23 PM
mikes300's Avatar
mikes300
BT makes a LL for the rear channels, with the one connector, the front and rear ones are different, you need a rear one.
Old Mar 2, 2020 | 05:33 AM
Dsm Limited's Avatar
Dsm Limited
If you want fade and are riding a SG or RG, you'll want a rear line leveler also. You will need to have the head unit flashed for the 4speaker 0amp "Ultra" flash.
If you're on an ultra, limited or RG ULTRA, you will need the BTBOC harness from BT. Those models will already have the 4/0 flash.
klaybus
Audio Systems
Jan 12, 2020 10:36 AM
AdmiralAaron
Audio Systems
15
Aug 17, 2016 04:42 PM
claytucc3
Dec 26, 2014 08:09 AM
aaazdaddy
Audio Systems
Jan 27, 2013 08:36 AM
wrenchguy24
Dec 25, 2011 10:36 AM
