Dilemma
Old Mar 24, 2020 | 11:08 AM
haze324's Avatar
haze324
Originally Posted by jester0618
No flash, set at 4/0 already. I did unplug the speakers from the amp, and am not getting good readings in voltage out. Spoke to Andy last night and I am turning down the master volume on DSP and then trying again this afternoon.
DSP input voltage is straight from the battery.
I'm going to try the master volume at -10 first and go from there. I already have the gains (front and rear) at zero and have tried small adjustments.
More details this afternoon I hope. Maybe the one change will make things fall in line.
Input voltage is signal source, not battery. So the voltage coming out of the radio into the DSP, and then going to the amps. Other DSP's have an input voltage setting so you can match the source signal voltage going into the DSP to what is coming out of the DSP. The 4/0 flash is a very crappy sounding signal with boosted voltage and will make tuning your bike with a DSP challenging at best.
Old Mar 24, 2020 | 11:20 AM
jester0618's Avatar
jester0618
I know that there are other flashes that would be better. 6/2? But, until this "crisis" is over and places start running again, I"m stuck with what I have.
Being the audio dummy, can I assume that by pulling the rca inputs I'd be able to measure the voltage from the radio? I am running from the molex (factory) to vtwin audio cables to rca inputs.
Old Mar 24, 2020 | 11:36 AM
eaglefan1's Avatar
eaglefan1
Alex, or anybody that knows and/or help.
In the OP's pictures posted you have on the bottom left a "Volume". Each channel has a vertical slide bar with db, OP's are set at 0db.
Could you explain how these should be set in relation to each other. Why should adjustments be made to each one and the reason for.
Im still learning on my DSP and I will for a long time! Id really like to be looking over watching a bike getting tuned to learn how to do it. Not looking to make any money tuning that's for sure. Just want to gain some knowledge for future modifications
Old Mar 24, 2020 | 01:14 PM
FrenchieM's Avatar
FrenchieM
Until you start moving the sliders yourself and hearing what that does you won’t understand. Seriously play around with the program and see what your ears pick up from doing it.
Old Mar 24, 2020 | 02:54 PM
eaglefan1's Avatar
eaglefan1
The individual channel ones I have moved, the one all the way on the left I have not. The channel sliders lower or raise the volume, so more or less volts going out? Those are the questions I have. Not just what they do but why to use them? To get the system to be balanced?
Old Mar 24, 2020 | 05:44 PM
marcodarq's Avatar
marcodarq
the channel sliders and just that, a control for each channel, the main slider on the left is like a global control, that raises or lowers them all together. turn all your sliders down a bunch, turn up the gain on you amps just a bit, then check how it sounds, you;ll get a feel for it. Like Haze said, your flash is going to hold you back a lot. many indy shops have the tool to flash your head unit, maybe make some calls.
turn the main slider down, turn the channel sliders down, turn the gain on the amp to like 1/4 turn off zero. play some music, while paying, raise your channel sliders a bit and check sound, if good turn up the main a bit, repeat process until you have good sound with no distortion or other issues. it's a mixing game!
after you make your first adjustments, go back and recheck your eq stuff, repeat until happy, and dont release the magic smoke.
m
Old Mar 25, 2020 | 07:24 AM
jester0618's Avatar
jester0618
I pulled all the vtwin harness stuff I had installed (to avoid cutting wires) and have ordered a converter. I'm not getting readings out of the amp (voltage) that make any sense so I'm eliminating possible issues. ONce that is installed, I'll try again to set the gains. I know that a flash would help more, but until shops open for business, that will have to wait.
Another reason to remove the harness is the feedback/hissing/staticy noise I was getting with volume muted. Reducing connections, etc. Fresh speaker wires being run to all 4 corners to combat this.
Thanks for the input so far, will have more in a few days once the parts show up.
Old Mar 30, 2020 | 07:40 AM
jester0618's Avatar
jester0618
Ok, update time.
Thanks for all the input, but especially thanks to Andy. Thanks for putting up with my constant barrage of questions.
With the vtwin audio cables/harness' pulled out, sni-35 installed, I have an amazing sound now. I set the gains to ~22 volts and everything sounds great. Even with my 4/0 flash. I called a local HD, but nope, won't do the flash without their boom junk installed. A local indy place wants 70 bucks to do it, says it takes an hour.
I'm planning a trip to visit Andy in Illinois in the next few months (covid dependent) and get my system flashed, tuned, and some beers drank.
Thanks again to all for your help. Until I do bag lids! LOL
scrapper
Touring Parts
Jan 3, 2020 12:08 PM
JMC22
Audio Systems
11
May 14, 2019 09:21 AM
azmaniac
Jan 14, 2018 07:59 PM
Bike medic
Audio Systems
25
Mar 6, 2017 12:52 PM
yzergod
Audio Systems
May 4, 2014 10:11 AM
