Fairing only system.
Old Mar 29, 2020 | 08:30 AM
Streetgliderr's Avatar
Streetgliderr
Default Fairing only system.
I am finally looking to upgrade my stock 2007 fairing stereo. Flhx. Best bang for the buck. Like quality. Budget up to $1500. Thanks.
Old Mar 29, 2020 | 08:53 AM
cshocker's Avatar
cshocker
Stock head unit?
Old Mar 29, 2020 | 10:57 AM
c_mancuyas8's Avatar
c_mancuyas8
You can do this under $1500 and have a very loud and clean sounding fairing setup.
Kenwood KMR-D772BT $150-200
2- Beyma 6p200nd 8ohm $450+/-
or
2 Beyma 6g40nd 8ohm $340+/-
or
2- faital rs140 8ohm 290+/-
2 horns- prv $90, DD $160, gz $200
soundigital 800.4 4ohm $450+/-
Dayton dsp 150$
Old Mar 29, 2020 | 11:05 AM
Streetgliderr
Originally Posted by cshocker
Stock head unit?
​​​​​​Yes but looking to get newer with an amp and couple 6.5's
Old Mar 29, 2020 | 11:08 AM
Streetgliderr
or
or
Dayton dsp 150$
Wouldn't 8 ohm be too high. Would really need a powerful amp to drive them to loud volume? Not sure
Old Mar 29, 2020 | 11:13 AM
c_mancuyas8
No, you'd run them parallel and bridged across 2 channels on the 800.4 getting 200w ea, then a horn on each of the other 2 channels. I use the faitals on that exact amp and they're very loud with punchy bass
Old Mar 29, 2020 | 11:21 AM
Ron D 33's Avatar
Ron D 33
I would get the Beyma 6P200ND 4 ohm and JL Audio XD 600/6. Run it bridged to each Beyma and two channels left over for the horns. I'd get the Ground Zero GZCT-500IV-B to pair them with. That puts you at $1,000-1,100 spent and get what deck and DSP your prefer with the rest.
Old Mar 29, 2020 | 11:26 AM
Streetgliderr
Is a dsp necessary? Can't just use head unit that I purchase? Where do you mount the horns. Thanks.
Old Mar 29, 2020 | 11:31 AM
Ron D 33's Avatar
Ron D 33
You're definitely going to want a DSP to dial everything in. The horns will fit to the side of deck in the gauge holes.
Old Mar 29, 2020 | 11:32 AM
c_mancuyas8
It's makes such a big difference with pro audio setups that I say yes. I've got my horns mounted in the mirror holes of the fairing and another set below the bars
