Hi all. First time poster here. I currently have a 2004 Heritage that I’m looking at adding an audio system to. There seems to be tons of different options and many mixed opinions. Can you folks recommend any that you currently use or have in the past? Thanks for the help!
Not sure when/if this post will get moved..... but.
Depends on how far you want to go, options range from ear buds (modify your helmet), Calvary helmet (other helmets available) , blue tooth speaker tube handle bar mount (or separate clamp on your crash bars, exc.), speakers in your bags (or go with hard bags and put them in the lids), all the way up to adding a clip on fairing with a stereo.
I have a clip on fairing with a marine blue tooth stereo and four marine speakers.
Very light and takes 2-3 three minutes to remove/install.
I also have a Calvary helmet.
Depends on my mood, when I want music I want music available.
I always have it on road trips (especially riding by myself).
i put a fairing with infinvity marine prv 250 head unit, four rockford fosgate 5.25" speakers, added a 1000 watt stealth class d amp in fairing. Left room in fairing to add second and third amp if i want to mount speakers in lids or i can put two 7 inch or 8 inch speakers on my hwy bars like a wake tower.
