my system has 4 4channel amps equaling 12 channels with some bridged i am down to 10-12 channels
amp 1, 2 fr and 2 rr tweeters = 2 chnl
amp 2 , 2 fairing and 2 lowers = 4 chnl
amp 3, 2 bag lids 6.5s bridged =2 chnl mono and this amp has two, .....(one bridged or two stereo chnl unused),... maybe comp driver inside bag? =2 more chnl
amp 4, 2 10s in bags bridged=2 chnl mono
total =12 chnl
what do I do? it looks like all dsp's are 8 chnl . consolidate channels? 2 dsps?
2nd dsp is what i was thinking. like 2 six channel? is there a way to link them or does it really not matter? are all channels independent of one another anyway? are there equalizer curves and such?
as you might have noticed i have never used or experienced a dsp yet.
using some of the channels mono works as well, as i hadn't even considered that option, basically because i thought each amp needs a left and a right channel to produce max wattage even if there bridged, mono.
havent pick out a dsp yet, that is what i need to know, i have no clue which one would accommodate this system the best, it was recommended to use dsi-2 or rockford both 8 chnl
so far its mostly prv, 450 tweeters frt and rear, 500s in lowers 500s in upper, 6x9 in lids for now, probably will end up 6.5 sealed back in lids, and 10s in bags its currently using 10 channels.
The DD Dsi2 has 8 channel of processed out put and 2 non processed, you can use those 2 outs to link to another dsp and make life kinda easy if you have the space.
m
