Let me reword my battery post question
Old Apr 20, 2020 | 07:15 AM
123ozzie's Avatar
123ozzie
Default Let me reword my battery post question
How are you guys getting your starter wire, a 4 gauge amp wire, and maybe one or two (battery tender for example) other power wires on the positive and negative battery posts? Thanks in advance for any responses.
Old Apr 20, 2020 | 08:04 AM
decencyxdefied's Avatar
decencyxdefied
Mine all fit fine with the right size ring terminals offset so they are not all stacked up
Old Apr 20, 2020 | 08:25 AM
Weeboy1's Avatar
Weeboy1
Yup, proper sized ring connectors . No problem.
Old Apr 20, 2020 | 08:32 AM
SBates08's Avatar
SBates08
There's nothing that says you can't change your battery bolt to one just a tad longer to accommodate your needs either.
Old Apr 20, 2020 | 10:25 AM
123ozzie's Avatar
123ozzie
Thanks for the responses. I just found a lug/screw made by Rockford Fosgate that enables you to tighten down your starter wire, then allows you attach your amp wire to the top of it. Basically allowing you to stack multiple eye terminals. Also, you can remove the amp wire without interrupting the starter wire if need be. Hopefully it’s not too tall.
Old Apr 20, 2020 | 11:10 AM
Fireball Jack's Avatar
Fireball Jack
link to that?
Old Apr 20, 2020 | 01:38 PM
123ozzie's Avatar
123ozzie
Originally Posted by Fireball Jack
link to that?
Amazon Amazon
My problem is the lead part of the battery that makes contact with the ring terminal from the starter is not flush with the top of the battery, its indented a bit. Hard to explain. It's difficult to add another ring terminal from the amp. Hope this makes sense.
Old Apr 20, 2020 | 01:41 PM
123ozzie's Avatar
123ozzie
https://www.sonicelectronix.com/item...ctpage-nosto-1
Here's another
Old Apr 20, 2020 | 03:31 PM
123ozzie's Avatar
123ozzie
Ok, disregard the links. After I researched them a bit more, they are the wrong size thread size for a motorcycle battery. Sorry for the confusion.
Old Apr 20, 2020 | 04:20 PM
wils5150's Avatar
wils5150
doubt it will work. think it might be too tall and the wrong thread size. let us know if it does work though
