ABS light and no rsp B code after upgrade
Old May 5, 2020 | 11:04 AM
glsec507's Avatar
glsec507
Default ABS light and no rsp B code after upgrade
2011 FLHTCU sub 30,000 miles
Anyone have this happen after upgrading their audio? I get a no rsp in the "b" code section. I also get a constant on ABS light that comes on after Ive been riding a ways. I figure I need to check the ABS sensor wires to make sure they are intact. I know the bearings were installed properly because I did them myself. I am also not getting any codes for the ABS system.
Im curious if disconnecting the stock wiring for an after market radio and installing the added amps and speakers would have something to do with these two things.
Old May 6, 2020 | 06:10 AM
glsec507's Avatar
glsec507
After clearing the codes and having the ABS light return multiple times the bike is finally showing codes C1025 C1216 and C1095. As best I can tell this is related to the front wss.
Per the electrical diagnostic manual one of the causes of C1025 is electrical noise on the wss wires.
Where do you run your power and ground? What side of the bike, inside the harness tray, on top of the tray? Mine are both 4ga wires ran along the left side of that harness tray all the way into the fairing. I didnt think there would be any way to fit them inside the tray. However this path runs right across the wss wire where it comes out of the harness.
Has anyone had electrical interference in different sensors on the bike due to all these extra wires?
Just trying to chase down this ABS issue. I started right after I installed everything.
glsec507
May 8, 2020 10:45 AM
1fathog
Mar 22, 2013 07:21 AM
glide2005
Jan 17, 2011 11:56 AM
DocDyna
Dec 2, 2009 07:59 AM
05 FLHTPI
Feb 14, 2006 10:45 PM
