DSP install.
Old Jul 7, 2020 | 10:13 AM
JimTJr's Avatar
JimTJr
Default DSP install.
I cut the headlight tabs off, (only hold plugs in place under fairing) Then I cut the inner "Rib" where headlight bolts on top. DSP sits cleanly between those and gives me another 3/4 or 1" deeper position. After I understood what to cut, install made sense when many said, on top of HL. I used two sided tape, (GOOD 3M) and just did those tie straps as "insurance" I put good pressure under the DSP trying to lift it after it was in over night. It's held good with the tape. (Front and down both sides on the "Rib" I cut down.
