Stereo no sound from speakers
Old Jul 8, 2020 | 07:35 PM
Johnny bad's Avatar
Johnny bad
5th Gear
Default Stereo no sound from speakers
I have a 2011 Flhtk. Stereo sound cuts out random. J&K 500 watt amp and speakers. Amp shows no sign of overheating. Green light stays on. Hit speaker switch and will sometimes work but not for long. Now no longer works. No codes on raidio. Any help please.
Old Jul 8, 2020 | 08:02 PM
FUJILICIOUS's Avatar
FUJILICIOUS
Might try the audio section. Lotsa geniuses about this stuff over there.
Old Jul 8, 2020 | 08:39 PM
nevil's Avatar
nevil
Welcome to the forum.
Old Jul 9, 2020 | 08:10 AM
LQQK_OUT's Avatar
LQQK_OUT
The radio is most likely broken. You have a couple of options:
1. Send it in to be repaired at Iron Cross Audio. Expect to pay at least $250.
2. Repair it yourself. Or if you do not have the ability, maybe you can find someone. Cost would probably be under $50.
https://www.hdforums.com/forum/audio...epair-diy.html
Here's a parts list of items available from Amazon:
A. TDA7563 STMicroelectronics Audio Integrated Circuit New, from Amazon
B. Innovation Cooling Graphite Thermal Pad (30 X 30mm), from Amazon
C. ASI 388 Clear Electronic Grade Silicone, from Amazon
D. MG Chemicals 422B Silicone Modified Conformal Coating, 55 ml Bottle, from Amazon
3, Look into replacing your radio. If the CB, Intercom, Headset and rear speaker volumn adjustment features aren't important to you, you should look into the new Rockford Fosgate PXM-HD9813 radio.
https://www.rockfordfosgate.com/prod...ls/pmx-hd9813/
Old Jul 9, 2020 | 08:21 AM
Johnny bad's Avatar
Johnny bad
5th Gear
I'm new to this so please bear with me.
Old Jul 9, 2020 | 08:56 AM
Tailwind's Avatar
Tailwind
Have u bypassed the amp and run HU straight to speakers?
T
Old Jul 9, 2020 | 09:49 AM
Johnny bad's Avatar
Johnny bad
5th Gear
I have not tried that yet. Maybe this weekend. I also have an old unit from my 09 flhx I was going to try and hook up but not sure if that will work the same.
Old Jul 9, 2020 | 10:22 AM
Tailwind's Avatar
Tailwind
Yup. Trouble shooting mode. Could be anything. Start by isolating the HU and the amp. Then if the HU works trace every wire from the HU and battery to the amp. One loose connection will jack things up. Then track amp to speakers.
But make sure ur prob isn't the speakers themselves when u run HU yo speaker.
T
Old Jul 9, 2020 | 11:43 AM
danzio's Avatar
danzio
You may want to start by rewiring all the connections from the HU to the amp to the speakers. Likely something not making a solid connection. That is a cheap and easy task and you may not need to go any further.
Old Jul 9, 2020 | 12:04 PM
IBE's Avatar
IBE
you have a harmond kardon radio its the radio. Iron Cross radio will take care of you. common problem
