SBD lids
Old Jul 22, 2020 | 07:58 PM
jester0618's Avatar
jester0618
Default SBD lids
Ok folks. Been fitting up the lids. Crazy 8s. Of course once the latch mechanism is in, the speakers don’t fit. PRV CF 8s. I took the dremel out and whittled away. Maybe something changed in 2020 but I had to take a lot away.
so, has anybody tried a 1/2” spacer? Raise the speaker up so the basket doesn’t hit the mechanism?
thoughts?
thanks
Old Jul 23, 2020 | 08:46 AM
marcodarq's Avatar
marcodarq
what part of the basket is making contact? if its not around the spider or the magnet support structure do you think that you can clearance the basket?
m
Old Jul 23, 2020 | 08:48 AM
jester0618's Avatar
jester0618
That is what is hitting. I used a dremel and really cut into the latch/lock mechanism. Still functions, sorta, and was able to make it fit. I wonder if I had gone with advanblack, would the angle have been better with less cutting? I'm searching for a 1/2" spacer, but the dimensions are not in my favor. Need 8.25 OD, 7.25 ID.
Old Jul 23, 2020 | 09:01 AM
jester0618's Avatar
jester0618
Looks better after smoothing, but the piece that keeps the cable sheathing from moving is gone. Will likely have to glue it so it doesn't move and will allow the cable to work.
Old Jul 23, 2020 | 10:01 AM
mikes300's Avatar
mikes300
I'd try drilling some small holes there and use stainless steel safety wire to secure the cable, should work much better than glue and removable if neeeded too.
Old Jul 23, 2020 | 10:27 AM
jester0618's Avatar
jester0618
Great idea! Thanks!
JC0311
Audio Systems
11
Oct 13, 2021 01:45 PM
GunslingersNation1
Audio Systems
Oct 31, 2019 10:15 AM
Kseeley
Audio Systems
Dec 14, 2017 09:09 PM
chevdude
Audio Systems
Nov 17, 2016 02:04 AM
Lemayco
May 15, 2012 08:01 AM
