Need more bass
Old Sep 19, 2020 | 12:31 PM
Ali85955's Avatar
Ali85955
Default Need more bass
Hi all,
I have a roadking with the below setup:
Twisted 8 lids
1 set of Hertz st25 in the lids powered by Sd250.2 amp
1 set of Hertz SV200 neo in the lids powered by 1 SD800.4 EVOX (bridged)
I am looking for bass, what do you guys recommend.
Thank you in advance.
Old Sep 19, 2020 | 04:53 PM
cpbedor's Avatar
cpbedor
Hertz 200Ls will deliver much more bass than your neos.
Old Sep 19, 2020 | 05:15 PM
Ali85955's Avatar
Ali85955
You mean to replace the neo with the 200L or add the 200L to the set up?
Old Sep 20, 2020 | 04:17 AM
highwayman50's Avatar
highwayman50
FWIW not being the poster...sounds like replacing the neo is the suggestion.
Old Sep 20, 2020 | 08:09 AM
travelingypsye's Avatar
travelingypsye
I do know with the right tune those 200L’s pound like no tomorrow. They are a mid bass where the memos are mid range.
Old Sep 20, 2020 | 06:53 PM
SBates08's Avatar
SBates08
If the 8" lids are your only source of audio, I wouldn't recommend the 200Ls. The bass that you gain from them won't be enuff to offset the mids you'll lose. Bad *** speaker though. They'd work great inside the bags along with what you have already though. You would need a baffle for the 8's in the lids.
Old Sep 20, 2020 | 07:35 PM
travelingypsye
How high are you running your L.s? Will they run to say 2000? Specs say they will go 4500 but im not sure where they start sounding bad.
Old Sep 20, 2020 | 08:32 PM
SBates08's Avatar
SBates08
Mine are currently set a 55-400@500watts. They will play higher but they're not what I would consider a solo speaker for a lid only setup.
Old Sep 20, 2020 | 08:47 PM
ReDo's Avatar
ReDo
I completely agree with @SBates08. If you are going to just run lid speakers, I would not swap. If you want to add speakers to the inside of your bags to get bass, the 200Ls would be good but you would need to separate them from the lids. I sealed my bags and put two Ground Zero Yellow Baskets in them with 400Watts to each and you can feel the bass on your legs a couple of feet away. But you can’t really hear it when riding. Bass is lost when rolling down the road, so just keep that in mind. If you decide to go down this rabbit hole for bass it is for the parking lot. Not trying to talk you out of it, it was important enough to me to spend the $ to get it, but just worth knowing going in.
Old Sep 21, 2020 | 09:16 AM
Adenton528's Avatar
Adenton528
Faital 10's, sealed bags, keep the hertz in the lids, get a tour pack for a 1600.1 to drive the faitals.
