8 speaker setup
Old Jan 30, 2021 | 03:32 PM
Frost's Avatar
Frost
Default 8 speaker setup
Hi, looking for any opinions. I have a reckless fairing with 4- 5.25" millennium speakers a Sony XAV-8000ax head unit with a built-in internal amp that has a 20 watts RMS 55 peak x 4 channels. I plan on adding a Kenwood excel Xr-400 4 channel amp with 1-Polk Audio MM692 6x9 in each bag and 1 polk DB652 6.5" in each lower for a total of 8 speakers. What would be the best way to wire this setup? Thanks in advance
Old Jan 31, 2021 | 11:28 AM
Ndfastln's Avatar
Ndfastln
Those fairings are tight on space and difficult to put multiple amps in, but you'd be better off using the Kenwood amp for the 5.25's and adding another amp for the lowers and bags. Maybe a SD 800.4, or Stinger SPX700.
Old Jan 31, 2021 | 11:45 AM
SOFTPETER's Avatar
SOFTPETER
The speakers are pretty entry level and do not require that much power.
Just run the amp at 2 ohms and you will be ok.
If at all possible never use deck power.
Ali85955
Audio Systems
19
Mar 17, 2024 12:10 PM
Steve Petrie
Audio Systems
Jul 25, 2019 05:10 PM
Quickrunner1
Audio Systems
Mar 31, 2019 07:23 PM
Philokc
Jun 24, 2016 09:21 AM
Non11
Audio Systems
30
Feb 14, 2013 08:34 PM
