Lower Fairing Speakers
Old Feb 6, 2021 | 08:51 AM
harleysteve's Avatar
harleysteve
Default Lower Fairing Speakers
I have a 2019 FLHTKSE fitted with Stage 1 Boom Audio. Can I add the second amp in the Tour Pack to run the Rear speakers and use the front Amp in the bat wing to run a pair of Lower Fairing speakers? If so will I need to make up custom wiring or is it just plug and play? I don't want to have a second amp in the saddlebag if I can avoid it. I also have a detachable Tour Pack kit so when I remove the TP both the speakers and amp can come off together
Thanks
Steve
Old Feb 7, 2021 | 08:49 AM
JMJOHN's Avatar
JMJOHN
Sponsor
Steve ,,,, I believe you would be much further ahead to remove the front mount Boom I amp, and replace it with an amplifier you can adjust, so that you can add LOWER fairing speakers ,,,,,
with the 800w J&M ROKKER amp you could also add lid speakers to the rear, and connect in series with the rear trunk pod speakers ,,,,,,,
radio reflash is easy with the techno-research digital technician for consumer use ,,,,,,,
you can send me an email direct or post on the J&M Corp page here on HD forums for more info ,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
BrandoSando
Audio Systems
Aug 25, 2020 08:41 AM
hermsker
Audio Systems
Apr 29, 2020 06:34 PM
JEEPREGAL
Audio Systems
29
Feb 9, 2020 05:18 PM
howertonv
2014-2024 Touring Models
Jul 7, 2017 10:16 AM
smittydog27
Audio Systems
Dec 12, 2014 02:55 PM
