Amp wiring
Old Feb 8, 2021 | 04:17 PM
05sportie's Avatar
05sportie
Default Amp wiring
Ok so I’m trying to figure out how I should wire this stuff up, I’m running a 4 6.5 polk mm1 I have a soundigital 800.4 amp 4ohms. So what I did was ran only two channels. So two speakers are wired in parallel and running as 2 ohm and in one channel then did the same thing for the other channel. So I that leaves me 2 more channels. People are telling me I need to run them separate on each channel. But it plays fine and is loud as hell as I have it. I was gonna run two 6x9 but not looking to add another amp. Any info would be great thanks.
Old Feb 8, 2021 | 04:22 PM
USAproud's Avatar
USAproud
What you did is fine as long as you are happy. Just make sure the 6x9 you add are efficient with the remaining power
Old Feb 8, 2021 | 09:07 PM
05sportie's Avatar
05sportie
awesome thank you. I was gonna do the same with 6x9 and bridge them or just run them on there own channel. So I should be good
Old Feb 8, 2021 | 09:45 PM
cshocker's Avatar
cshocker
I don’t believe you can run a bridged 2ohm load on that amp.
abadv8
Audio Systems
33
Jun 15, 2020 03:06 PM
Biggzed
Audio Systems
Jan 11, 2019 10:25 AM
deadduckflying
Audio Systems
Dec 12, 2017 09:41 AM
SALBEEZY
Audio Systems
Jul 8, 2014 11:54 PM
mhill0826
Audio Systems
Apr 5, 2013 10:22 PM
