Quick question about 6.5 adapter
Old Feb 23, 2021 | 05:13 PM
T-G's Avatar
T-G
Sorry had a water main leak at my house so I worked on that all evening yesterday
6.5 adapter kit
Old Feb 23, 2021 | 05:18 PM
Ali85955's Avatar
Ali85955
Originally Posted by T-G
Ok guys thanks I will give it another look tomorrow evening when I get the chance thanks again
going to be installing GZ when they ce in but have the mmats installed right now
How do the mmats perform in the fairing, I always wanted to try them and my friend is thinking of installing them in his fairing.
Old Feb 23, 2021 | 05:24 PM
T-G's Avatar
T-G
Granted I'm still running the hogtunes aa 450 amp which is 50 watts rms per ch but after I tuned the crossover on the RF head unit they are loud and very clear so I can imagine it would be very good with a good amp tuned.
I think I would have been very happy with them on the ss pn4.1000d.
But I already ordered the GZ yellow basket and the SD 800.4 so I may end up selling these
Old Feb 23, 2021 | 05:31 PM
SBates08's Avatar
SBates08
6.5 adapter kit
I've never used that adapter so it's hard to say. How close is it to getting the brace to bolt back up.
FWIW....I took both of mine out.
Old Feb 23, 2021 | 05:33 PM
T-G's Avatar
T-G
The adapter has multiple holes for the 6.5 so I thinking I maybe one hole off the throttle side lined right up perfectly
Old Feb 23, 2021 | 06:05 PM
SBates08's Avatar
SBates08
Ok. The adapter itself will only bolt up one way. Just position the speaker in the closest hole that will line up with the brace and make the necessary adjustments to the brace. About all you can do.
Old Feb 23, 2021 | 06:28 PM
T-G's Avatar
T-G
Yes the adapter only go one way but for the 6.5s there seems to be more then one set of holes
I will look at it when I take it back apart I will take a picture of it and what I find out
Old Feb 23, 2021 | 07:12 PM
SBates08's Avatar
SBates08
You don't have to use the predrilled holes. Move the speaker around until your brace lines up and drill new holes in the adapter. Problem solved.
Old Feb 23, 2021 | 07:48 PM
SBates08's Avatar
SBates08
Just for reference, this is the Metra 82-9601 adapter. Lines up every time. Quick question about 6.5 adapter-photo487.jpg
Old Feb 23, 2021 | 07:51 PM
T-G's Avatar
T-G
Thanks my throttle side went just like that it was just the clutch side was about 1/2 in off. So I just need to reclock it
thanks
jfrizman
2014-2024 Touring Models
14
Feb 20, 2017 10:42 PM
Liquidoxygen
Mar 16, 2015 09:48 AM
2swild
Feb 27, 2012 12:30 PM
cfoster80
Nov 25, 2008 07:25 PM
