dsp
Old Feb 23, 2021 | 06:38 PM
Scooby1426's Avatar
Scooby1426
Default dsp
I currently have 2 amps & fairing speakers with lower speakers. Also have the bt ll355 on my bike also. My question is: If i have my bike re flashed with the Rockford fosgate flash will i need a dsp?
Old Feb 23, 2021 | 08:42 PM
teedoff65's Avatar
teedoff65
DSP controls the freq range and such of the speakers. Whether you should run a DSP is has more to do with what speakers you are running.
Old Feb 24, 2021 | 07:00 AM
Scooby1426's Avatar
Scooby1426
My speakers in the fairing are DD AW6.5 with the AT28"S JL XD 400/4 AMP
Lowers have the Mmats 601cx with a GROUND ZERO MICRO 4 AMP
I was looking into getting rid of the line levelers, having it re flashed, that was why i was asking if i will need the dsp. Was looking into the DRS1 from Fosgate.
Old Feb 24, 2021 | 08:23 AM
teedoff65's Avatar
teedoff65
I think in your case, running horns, yes you would benefit from running a dsp. Sometimes horns can be too harsh with the screeching highs.
I would suggest you check out the Dayton 408 dsp though. I hear its much more user friendly. If you've never used a dsp to tune a bike, the learning curve is IMO a little daunting though.
Old Feb 24, 2021 | 10:53 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Shoot any system can sound better with a DSP Scooby.
When I first got my DSP all I did was play with the EQ sliders on each channel to get a sound I liked. That alone made a HUGE improvement in sound quality. As time went on and I put some miles on it I learned more about the functions of the unit and was able to make it sound even better to my ears.
Also from what the smart folks here have said when you flash the Harley head unit with something like the Rockford flash you have a cleaner signal to work with no matter what you choose to do. That will translate into less distortion going into your amp.
Old Feb 25, 2021 | 06:51 AM
Scooby1426's Avatar
Scooby1426
Thank you for your responses. I am not sure what dsp i will get but will you tube some. I will flash the radio when i get the bike out of storage & proceed from there. Back when i did this the line levelers what everyone was using, now a whole different ballgame.
Ali85955
Audio Systems
Mar 10, 2021 02:01 PM
Eric Steward
Audio Systems
15
Sep 20, 2019 08:56 AM
NMfxdf
Audio Systems
Oct 17, 2018 03:07 PM
paid4c4
Audio Systems
25
Apr 6, 2018 02:47 PM
scottdoege
Dec 23, 2011 10:01 AM
