wiring amp?
Old Mar 9, 2021 | 01:23 PM
ultraglide12's Avatar
ultraglide12
Default wiring amp?
i got stage 2 boom so 6 speakers and 3 amps i geuss i want to swap amps with most likley a stinger amp but what is needed to replace boom amps do i need some sort of tee harness or something? im still running factory head unit i have changed 4 of speakers out so far just the lids are boom until amp swap. i need a parts list for new amp other than power/grd
Old Mar 9, 2021 | 01:34 PM
cshocker's Avatar
cshocker
It's all or nothing with Boom. Replace amps and all speakers, or leave it all in. Any other amps will be too much for those Boomtastic speakers. Any other speakers with that Boomtastic amp, won't get enough power.
Old Mar 9, 2021 | 01:41 PM
ultraglide12
I already changed front speakers out .I been waiting on rears till I get a new amp installed I just need collect parts till I'm ready for swap that's why I'm asking for what I need for parts
Old Mar 9, 2021 | 01:42 PM
teedoff65's Avatar
teedoff65
List all the speakers you're planning.
Have the HU flashed? Or running BT line levelers?
Old Mar 9, 2021 | 01:43 PM
SBates08's Avatar
SBates08
The Stinger isn't going to run 6 speakers. Just not enough power. We need to know what speakers you're using.
Old Mar 9, 2021 | 01:49 PM
cshocker's Avatar
cshocker
Looks like it's a 2012. So if true, it's the old HK head unit.
ultraglide12
I thought I could run the lowers and the fairing as fronts and lids as rears ? Right now I have 6.5 polk's and db drives in lowers
Old Mar 9, 2021 | 01:50 PM
ultraglide12
yes it's a 2012 is that going to be a issue
Old Mar 9, 2021 | 01:52 PM
teedoff65's Avatar
teedoff65
I not sure you should wire front lowers and uppers to the same channel. Want to be able to set gains and freq differently. They have different requirements coming from different locations.
Old Mar 9, 2021 | 01:54 PM
ultraglide12
as right now polk's 6.5 and db drive in lowers . I can swap speaker out out if need be later on.
I'm just not sure on amp wiring that is needed
