CVO amp install question
Old Mar 17, 2021 | 07:14 AM
Houston_t's Avatar
Houston_t
Default CVO amp install question
So I have a 2020 Street Glide CVO and I am trying to figure out what parts I need to get rid of the 2 Boom amps and go with 1 amp in the fairing. If possible would like to use the stock wiring for the rear speakers so I can maintain use of the factory bag connectors.
Old Mar 17, 2021 | 08:27 AM
teedoff65's Avatar
teedoff65
What speakers are you going with? Which amp/amps depends on your goal and speakers you want to use.
I personally would run new speaker wiring. You can still put some quick disconnects for the new wiring as well.
Old Mar 17, 2021 | 09:16 AM
Houston_t's Avatar
Houston_t
For fairing probably yellow baskets if I can get my hands on some, Not sure on the 6x9s yet. I would much rather use the factory bag quick disconnects. I need to figure out what wiring harnesses I need to make this work.
Old Mar 17, 2021 | 09:20 AM
teedoff65's Avatar
teedoff65
Yeah, you need to decide on speakers first. Then pick an amp that will power them well.
Old Mar 17, 2021 | 09:14 PM
Houston_t's Avatar
Houston_t
Got speakers and amp pretty much figured out that’s not the issue, I’m trying to figure out what harnesses I need to order other than power wire to make the swap in my bike and use the factory quick disconnects if possible. Goal is to get rid of the 2 4ch amps and add 1 new amp and speakers.
Old Mar 18, 2021 | 07:03 AM
SBates08's Avatar
SBates08
Pretty sure Biketronics has what you need.
Old Mar 19, 2021 | 10:24 AM
SCORPION111674's Avatar
SCORPION111674
You will need two bypass plugs! Call American Hard Bag and ask for Tim and he will hook you up. Tell him Rodney sent you!
wolfpack29681
Audio Systems
Mar 3, 2020 02:05 PM
Cvo glide
Audio Systems
Aug 26, 2019 07:52 PM
3itodd
Screamin Eagle CVO Models
May 26, 2014 07:23 AM
RSDUDA
Audio Systems
May 20, 2014 02:24 PM
Loop4re7
Feb 1, 2013 07:25 PM
