ACC output voltage low
Old Apr 8, 2021 | 04:25 PM
William Gipson's Avatar
William Gipson
Default ACC output voltage low
Installed a set of speakers on my bike last year, used the accessory plug under my left panel. Once in awhile my security light would come on, but went off within a couple minutes. This year it’s been on and stayed on. Checked the codes B2113 came on (Acc output shorted low) all lights work (except rear flashers in hazard mode) nothing else has been done electrically to the bike in the last two years. What would cause the “Acc output shorted low” code?
Old Apr 11, 2021 | 10:59 AM
Budda109's Avatar
Budda109
My understanding as minimal as it is. You get that code when current is not detected somewhere it should be. Weather it's in accessory mode or running. So either take it in or start with fixing the rear flashers and see if that corrects it? You don't have to have added anything for it to fail. Sometimes **** just fails. Good luck
William Gipson
Apr 6, 2021 09:22 PM
Luis GodzirahGang Nieves
Aug 29, 2017 08:30 PM
Zman15
2014-2024 Touring Models
20
May 23, 2015 05:36 PM
Potato_Potato
Aug 21, 2011 10:32 AM
ultra2006
Feb 26, 2007 04:38 PM
