Which amp for fronts
Old Jun 8, 2021 | 08:54 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Originally Posted by Bigwillie
its hear not here, i would be careful who i take advise from.
Correcting grammar with bad grammar will not win you any friends here.
Old Jun 8, 2021 | 09:01 PM
travelingypsye's Avatar
travelingypsye
Its here not here? Makes a lot of since.
As you should. Then again you knew that.
Old Jun 8, 2021 | 09:02 PM
scott_0's Avatar
scott_0
he clearly knows how to spell the word, as he spelled it correctly the first time, so he made a mistake. get the **** out of here with that weak ****! You've been around since 2007, have you not been in here often? travelingypsye gives lots of good info for those looking for it.
Old Jun 8, 2021 | 09:11 PM
travelingypsye
Thanks scott. Just trying to help others not to make the same mistakes I have in the past.
Old Jun 8, 2021 | 10:49 PM
mcdc1224's Avatar
mcdc1224
Really?????? Dang, You really should find someone that can install your system..
Old Jun 8, 2021 | 11:02 PM
ProgMan's Avatar
ProgMan
Stage IV
deleted
Old Jun 8, 2021 | 11:05 PM
AZBadgerFan's Avatar
AZBadgerFan
It's "advice" not "advise".
Old Jun 10, 2021 | 11:33 AM
bucko72's Avatar
bucko72
Originally Posted by mcdc1224
Thats a good plan, post back and let us know what you think
Got it all hooked up but the right gz has a loud popping sound at about half volume. The rest can go to max and still sound good so I don't know if something is wrong with that one or what.. tried switching leads on speakers and the problem stayed with the speaker.
Old Jun 11, 2021 | 07:22 AM
teedoff65's Avatar
teedoff65
check all your rca connections.
Old Jun 11, 2021 | 09:57 AM
Tailwind's Avatar
Tailwind
Swap RCAs around to isolate and also do a polarity check w a 9v battery.
T
