Just a little help
Old Jul 10, 2021 | 10:34 AM
Fireball Jack's Avatar
Fireball Jack
Default Just a little help
I have a 2018 RGU that I am going to upgrade the audio on. Fairing and lids only at this time. I had planned on Mmats 601.cx and 690.cx with a Stinger amp. I am now rethinking the fairing. The Lids and 690's are on order. Can a bridgred 800.4 drive the Gz coaxial's off of the front two channels. . What is needed to get the stock radio to connect to the amp. Thanks
Old Jul 10, 2021 | 07:59 PM
Dsm Limited's Avatar
Dsm Limited
Yes you can bridge/parallel wire the GZ coax, however you'd want the 2 ohm version of that amp. The GZ speaker is 4 ohm, but when wired in parallel creates a 2ohm load. The 4 ohm amp is not 2ohm stable when bridged.
At that point you'd have to bridge parallel the 690s as well to create that 2ohm load.
To complete that you'll want a Pac Sni15 and the head unit flashed with either the RF, Soundz or HD 8/2 flash.
If it were me, I'd consider the SD1200 amp over the 800. This option would allow the 4ohm version wired straight up, leave headroom and options available for future changes.
Old Jul 11, 2021 | 09:00 AM
Fireball Jack
Thanks. I am looking at the SD 1200.4 EVOX 4 ohm. is that the amp you are referring too?
Old Jul 11, 2021 | 09:45 AM
Tailwind's Avatar
Tailwind
That's a good amp for ur situation but the wrong ohm version for ur situation.
If u wire parallel and bridged w 4 ohm speakers u need the 2 ohm version of the amp. U cannot bridge the 4 ohm version w a 2 ohm load. Paralleling two 4 ohm speakers equals a 2 ohm load.
1200.4 EVOX 2 ohm is the one u want.
T
Old Jul 12, 2021 | 08:27 AM
Fireball Jack
T
Thanks Man!
John K Olson
Audio Systems
Nov 21, 2019 09:15 PM
sevitz5
Audio Systems
17
Oct 30, 2016 07:21 AM
Andy Gallaher
Audio Systems
Jul 3, 2015 11:07 PM
ElectraLarry
Mar 21, 2010 05:05 PM
Q Hog
Mar 10, 2010 03:29 PM
