Dayton dsp install
Old Aug 3, 2021 | 09:46 PM
rsking45's Avatar
rsking45
Default Dayton dsp install
Not long ago I installed the SD800.4(bridged) and GZ yellow baskets in the fairing. Sounds really good and its loud.
So I had a chance to pick up a Dayton 408 dsp for a good price. I know it's not nessasary to run a dsp with what I have, but I'd want to learn about audio stuff.
So with no experience with DSPs, can anyone give some advice on how to wire the stock hu, amp speakers and dsp?
I'll run power and ground from the battery. What gauge and inline fuse will be best?
How does it all wire up?
Any help will be greatly appreciated
Thanks all
Old Aug 4, 2021 | 07:56 AM
D1127's Avatar
D1127
Thanks all
HU flashed?
Old Aug 4, 2021 | 09:05 AM
teedoff65's Avatar
teedoff65
As D1127 said...is your HU flashed? Also are you currently using a LOC to convert speaker level to RCAs?
Old Aug 4, 2021 | 09:15 AM
IIBADII's Avatar
IIBADII
The Dayton comes with an inline fuse on its wire harness. There's a few different ways to wire the DSP in.
You can purchase a T-harness, American hard bag has one and I believe NVS has one.
You can supply power/ground through amp inputs(not the best choice)
You can use a distribution block that you have power/ground if it's closer than the battery.
Wiring is straight forward after that, you don't need a Line Output Converter, you can wire the high input straight into the DSP. Radio>DSP>Amp. Your going to want to make sure that your remote wire turns the DSP on first and then the output turns the amp on.
Just because you have the DSP doesn't automatically give you better sound. There is more than just putting it into your system. The correct way is getting a RTA mic and using software to correct the speakers. You're also going to want to flash your HU if you haven't done so already. Seeing that you have GZ, you probably can get a file uploaded from another member to get you on the right track with your tuning. So you can just upload it to the DSP.
I hope this information helped.
Old Aug 4, 2021 | 09:30 AM
D1127's Avatar
D1127
Originally Posted by IIBADII;[url=tel:20096026
20096026[/url]]The Dayton comes with an inline fuse on its wire harness. There's a few different ways to wire the DSP in.
+++ on all of that. Most t-harnesses come with power( fused), ground,(both come off HU recommended) no need to run back to battery, switched 12v (acc), and remote turn on wire. I’m using the AHB harness makes it easy peasy. You have an accessory plug in you fairing on each side, plug into that. You do t have to go this route, just makes it easy. Definitely look at a HU flash first, would be best way to go.
Old Aug 4, 2021 | 01:11 PM
rsking45's Avatar
rsking45
Originally Posted by D1127
HU flashed?
Yes it is. Has the RF flash
Old Aug 4, 2021 | 01:22 PM
teedoff65's Avatar
teedoff65
Honestly, unless you're really wanting to dive in and learn, as mentioned, a dsp is a little bit of a learning curve. I'm struggling a bit with it now myself.
For component speakers, while there is some advantage to using a DSP, not sure its worth it for the novice like me lol
Also, if you get a DSP, expect to be tweaking your tune for the rest of your audio life. lol
Old Aug 4, 2021 | 01:25 PM
D1127's Avatar
D1127
Thats good. I believe you can retain your fade option with that if you want it. If going with DSP most will use the 8/2 flash, but you'll have no fade option. You should be good to go. Have fun man!
Old Aug 4, 2021 | 10:32 PM
rsking45's Avatar
rsking45
The RF flash I'm using doesn't have the fade option. I think there is 2 or 4 speaker option.
Old Aug 4, 2021 | 10:41 PM
rsking45's Avatar
rsking45
HU has the RF flash , and I'm currently using the pac nsi-15 loc to convert speaker leads to RCA.
I also have PAC nsi 35 and bt355 in my stash of stuff.
