Boom Box Infotainment System Issues
Old Sep 1, 2021 | 03:59 PM
marcw44's Avatar
marcw44
Stage II
Default Boom Box Infotainment System Issues
Hello all,
I have a 2017 totally stock Road Glide. The other day I plugged in my IPhone 11 via the USB port (as I always did), the Boom system recognized the my music library, showed me the song playing on the display, but there was no sound. I checked and rechecked both the connection and to see if the system was on speaker or headphones. it was on speaker. I unplugged the phone and my radio played through the speakers... I then tried using the GPS function, and again, it brought up the location on the map, but no sound out of the speaker. I went to my local dealer and they did an update.... However, when i left I still couldnt play my music from the phone or get sound using the GPS. As I said, the radio works perfectly but no other sound from the speakers.... Any ideas before I have to go back to the dealer and lose the bike for ???? days? I appreciate any firsthand knowledge....
Old Sep 1, 2021 | 06:54 PM
critter85's Avatar
critter85
Welcome to the Forum lots of good information here
Old Sep 2, 2021 | 01:53 PM
Erilflynn's Avatar
Erilflynn
Try toggling between anothet source i.e. FM. This happens to me all the time but as soon as I toggle back an forth from FM it’s fine
Old Sep 3, 2021 | 07:05 AM
cycle7447's Avatar
cycle7447
Community Influencer
You may have checked the connections - however, did you check the setup? Make sure you have the prompts on.
Next thing to try - play a song and while playing, toggle the volume up
Good luck
Old Sep 6, 2021 | 07:43 PM
Dsm Limited's Avatar
Dsm Limited
Each input device on the Boom radio is a separate volume adjustment. If Nav is reciting a direction, that volume control is separate from radio volume. As Cycle 7447 stated, run through the setup screens and make sure prompts are on. Also run through each input device and make sure the volume controls aren't down low or muted. Lastly, make sure your phone media volume is not too low or muted.
Mt2015!
Welcome Area Only
20
Aug 20, 2021 01:52 PM
Patrick Robichaud
Welcome Area Only
20
May 9, 2021 08:44 AM
Smokeless Joe
Welcome Area Only
20
May 9, 2021 08:01 AM
tensec50
Welcome Area Only
Mar 26, 2021 10:10 AM
Kevinp090
Welcome Area Only
20
Feb 28, 2021 07:26 AM
