GZ Coax tuning
Old Mar 28, 2022 | 09:39 AM
Tupp's Avatar
Tupp
Fireball -
I am curious to what you setup in your DSP for the GZ Coax and MMats. I am running a similar setup but havent tuned it yet at all. I enjoy the building/wrenching/pulling wires and so on. I just know when I am out of my depth and setting up the DSP to allow the speakers to do their thing is not something I know how to do.
Old Mar 28, 2022 | 10:31 AM
hamah's Avatar
hamah
Originally Posted by Dsm Limited
As far as amps sounding warmer, I'll have to respectfully disagree with Hamah.
lol.. no worries Dsm. This is another one of those things that will always be debated and why I said it was in my opinion. I was absolutely convinced I could tell the difference back in my "audiophile" days...and I could when it was a pair of McIntosh tube monoblocks up against an early-era solid-state amp. The eye-opener (ear-opener?) for me was when I had a unique opportunity to do blind listening tests using identical signal chains where the amps (all solid-state) were swapped out. There were 3 or 4 different amps (one of them the same as my own amp at home) and I think I was almost 100% incorrect in guessing which amp was which IIRC.
Old Mar 28, 2022 | 10:53 AM
golfblues's Avatar
golfblues
Well IMHO, all amps can sound different....in guitar amps you have Fender, Marshall, Mesa Boogie, Ampex and many more that have their own unique sound. Even amps within the same company sound much different. In home stereo McIntosh was always warmer (tubes), Yamaha was always very clean. Many other brands have their own sound but you need good speakers to hear the differences too. On motorcycles, well at 75mph with all the other associated sounds from the bike, can we really hear the difference? Maybe in the parking lot or slow speeds but once you get to speed, you need power and clarity to take over otherwise it's just distortion.
Old Mar 28, 2022 | 01:00 PM
teedoff65's Avatar
teedoff65
Good points. True, while a lot of sound is lost at speed, we tune with the bike sitting still in our garage and are trying to get THE best sound while tuning we can. Which should, in some way, translate to open road riding, to a certain degree. Every little bit of warmth helps, imo. Some ppl like a brighter sound. Not me, so whatever I can do to get more sound that I like from my bike, is a plus.
Old Mar 28, 2022 | 07:45 PM
Rcloud72's Avatar
Rcloud72
I most definitely could hear the difference in sound quality ( and I’d describe that difference as one being Warmer than the other or more mellow ) when I switched from my old stinger amp and went to a SD800.4. It was clearly different sound. My wife even noticed and she doesn’t care about any of it at all as long as she can hear “her” song when it plays.
Old Mar 28, 2022 | 08:57 PM
hamah's Avatar
hamah
While it's true that you can measure subtle differences between low and high-quality amps (particularly if there is induced THD) it's highly unlikely you would be able to reliably tell the difference between 2 amps of roughly the same quality, operating within the performance envelop (no clipping), with the rest of the signal chain being equal. Certainly not on a bike that's moving.
There were a few good articles published on AudioXpress that go into the whole debate (here and here). At the end of the first article, there's even a link where you can try to tell the difference between 2 different recordings (one through a solid-state amp and the other through a tube amp). Give it try.
The bottom line though is that if there is a difference it's subjective and that's good enough. I know I can't tell the difference using proper blind tests because I've tried. If you can that's great.
Old Apr 4, 2022 | 10:45 AM
Bluesman280's Avatar
Bluesman280
Just curious which of the two amps you felt sounded warmer, the Stinger, or the SD?
I have also noticed the same thing between a couple amps when doing a swap in my bike. I'll leave the 2 amps out of the discussion until I hear your answer.
Old Apr 4, 2022 | 10:48 AM
teedoff65's Avatar
teedoff65
I had the stinger mmats combo on my 17 for 2 years and loved that set up. I thought it sounded pretty good with decent warmth.
I've not compared stinger and SD amps side by side, but im running SD amps now. Different speakers though.
Old Apr 4, 2022 | 11:07 PM
Rcloud72's Avatar
Rcloud72
im not so sure I’m hearing a huge difference it just seemed like when I had the stinger amp running the same 4 speakers that I eventually swapped to a SD 800.4 for the same four speakers ( running roughly the same amount of power to them from both amps) that the sound quality seemed clearly better with the stinger amp. I’d consider the two brands about the same caliber quality wise. But what do I know. I can’t tune for s#%t and don’t know a great deal about audio in general. I based my statement earlier off of how much clearer and how much more I could hear all aspects of the recordings of the songs when played. I change my stuff around so much now days though that I can’t even remember what sounded best out of my last three or four different configurations. Which is why I decided just today to finish up the install I’m doing now and to leave well enough alone for this entire year of riding. Lol. We shall see if I’m able to do it soon enough.
Old Apr 4, 2022 | 11:12 PM
Rcloud72's Avatar
Rcloud72
i felt like the stinger amp sounded WAY better. Warmer is the best way to describe it. I know that word gets tossed around a lot but to me that’s the best description. The stinger seemed to play every range of frequencies clearer and made pro audio speakers sound more like regular lower efficiency speakers. But still loud af like a pro audio driver. But as mentioned earlier what I know about audio will fit in a thimble. So don’t put a whole lotta stock in my opinion lol
