Radio is louder with engine off?
Old Apr 22, 2022 | 12:44 PM
Oneshot660's Avatar
Oneshot660
Default Radio is louder with engine off?
Anyone have an idea how to fix this? Or link to the posts on here about it. I have done several searches on here and came up with 1 post that does not say much about this issue. 2015 sgs. Factory radio. It kind of annoys me that the volume decreases when engine is started. Had I known this I would not have added an amp.
Old Apr 22, 2022 | 01:00 PM
hamah's Avatar
hamah
Do you actually see a difference in the volume bars on the radio? If so that would indicate a different output level. If not it may just be the running flash bin file. It's well known that there are different EQ settings for when the bike is running and not but I've never heard that there was any difference in master output level between the stock bin files. Did you have the radio flashed when you added the amp? If so which flash?
Old Apr 22, 2022 | 01:29 PM
teedoff65's Avatar
teedoff65
Did you set your gains with a test tone and the bike running? I dont know alot about this, but the bike output voltage drops when bike is off, so setting gains when bike is off versus bike on, there could be a slight difference?
Old Apr 22, 2022 | 01:40 PM
hamah's Avatar
hamah
if any difference I think it would be louder with the bike running and the amp getting higher voltage. I know the stock off bin sounds much more dynamic than the stock on bin. I'm going to go out on a limb with a WAG but I bet it's not that it's less volume but just doesn't sound as "full" (almost like turning off the "Loud" button)
Old Apr 22, 2022 | 02:13 PM
teedoff65's Avatar
teedoff65
Agreed. I know the stock system has different eq settings for idle, versus bike on and bike running.
Old Apr 22, 2022 | 03:58 PM
Oneshot660's Avatar
Oneshot660
No volume bars do not change, you can hear the difference. No I have to had the radio flashed. I am still debating if I should have it flashed. If so is there a flash I should be asking for? I just wanted to do a little more research on theis topic. How does the radio know that the engine is on? Is there a certain wire you can cut on the back of the radio to disable this from happening,? Does it work like a remote wire for an amp? Is all I am trying to figure out. Will having my radio flashed fix this?
Old Apr 22, 2022 | 04:00 PM
Oneshot660's Avatar
Oneshot660
Yes all gains were set using 1khz test tone, using a multimeter on outputs of amp.
Old Apr 22, 2022 | 04:03 PM
Oneshot660's Avatar
Oneshot660
Yes does seem like this. But at the same time if tuned with bike running, and speaker outs putting less voltage out while it is running. When turning the engine off with more voltage out of speaker outputs it would be louder as the amp was tuned with less voltage input.
Old Apr 22, 2022 | 04:11 PM
Oneshot660's Avatar
Oneshot660
Do the after market head units do this same thing?
Old Apr 22, 2022 | 05:47 PM
hamah's Avatar
hamah
As the volume bars (master volume) don't change I'm almost certain what you are experiencing is simply the difference in bin files being loaded by the radio. Yes, generally speaking, you do want to flash the HU if adding aftermarket amps and that will help with this issue. There are a number of flashes that are good (RF, Harley 8 speaker/2 amp are 2 of the most popular used here). The radio is on the CAN bus and that's how it knows which bin file to load. No, there is no wire to cut to get around this. No, aftermarket HUs do not do the same thing as they are not on the CAN bus and flashed in that manner.
You could do some reading on this issue but you aren't seeing lower voltages across the board with the motor running. You are seeing attenuation in certain frequency bands. Supposedly this is to protect the audio system from blowing speakers when you crank up the volume at highway speed. IMO it's more likely that this is to make the crap stock Boom! audio system sound as good as possible when standing still. There is really not much you can do to make it sound great under speed. Some people will disagree and are perfectly happy with the stock audio system so there you go (but they don't typically hang out on this forum for obvious reasons).
