Test non working tweeter
Old Jun 7, 2022 | 03:35 PM
kloccwork419's Avatar
kloccwork419
Default Test non working tweeter
What can I do to test tweeters to see if they are fried or if the capacitor is bad? They were working fine and both just stopped at the same time. There a way to test the resistor?
They are hertz st35. The amp channels are working but Im not getting any sound out the tweeters
Old Jun 7, 2022 | 07:08 PM
kloccwork419
Figured it out. Its a trash design. Probably why they got rid of the screw on connections. They are set in melted plastic. If you turn them too tight, they break the very fine commection on the inside. Had to solder it back together and reinforce the cheap material with some gorilla glue so the screw connections wont turn when it was already tight
So if anyone is in the situation thinking they are fried, check inside to see if the connection tore off. Easy fix.
hojones
Welcome Area Only
17
Jan 15, 2010 05:53 PM
Larry33
Jun 22, 2009 08:47 PM
refrigerationbiker
Aug 11, 2008 01:24 PM
nemick
Aug 7, 2008 10:58 AM
jbhawley
Jun 11, 2008 05:50 AM
