Quick Hertz SV200L question
Old Jun 11, 2022 | 04:39 PM
kloccwork419's Avatar
kloccwork419
Default Quick Hertz SV200L question
Should the amp be set on Full of HP? Just bought these. Switching out the sv200.1s.
Old Jun 11, 2022 | 06:19 PM
madhunter60's Avatar
madhunter60
Is there a dsp in play?
Old Jun 11, 2022 | 06:46 PM
kloccwork419
No dsp yet. Bridged off evox 800.4 I have midrange in the fairing and tweeters in the bag too. Wanting more bass than the 200.1s have but wasnt sure if I should go Full or HP.
Old Jun 11, 2022 | 07:48 PM
madhunter60
I would Hp 80hz to 100hz
If you are running mid range, tweeters and the 200L's you really need to look into a dsp so you can bandpass your speakers and optimize your system. But these are just my thoughts.
Old Jun 12, 2022 | 06:32 PM
SBates08's Avatar
SBates08
The 200L's will handle 500 watts and will play down in the mid 50hz range but without a dsp in play I wouldn't dare try to play them that low. As mentioned before, 70-80hz on high pass is about the best area you'll find without a dsp.
Old Jun 20, 2022 | 04:26 PM
kloccwork419
Thanks guys. I do have a dsr1 but still havent figured the thing out. Besides not knowing how to tune with a dsp, what test tone should I use to set the gains on the sv200L?
maxxym
Audio Systems
Nov 8, 2021 07:54 AM
FrenchieM
Audio Systems
Sep 3, 2019 10:15 AM
JetRanger
Audio Systems
May 27, 2018 01:21 PM
Briguy1
Audio Systems
Nov 13, 2017 06:43 PM
CGP93
Audio Systems
Feb 20, 2015 04:14 PM
