So got my bike all up and running and it sounds 1000% better then stock. Thanks to everyone who helped and gave advice. Ended up with:
Rockford flash
SD 800.4
DSR1
MMATS PA601CX in fairing
MMATS PA690.4CX in the bags
I have the gains set a bit conservative I think at 20v (100w) on both front and rear with the crossover at 110hz/24db slope fronts and 90/24db rear. No adjustments to the eq yet. Anyone willing to share their file or give suggestions on where to go from here? I would really like to have a file to compare to before I start messing with it a ton myself, make sure I am headed in the right direction and possibly save myself a ton of time.
