Missing Menu Item / Wireless Headset
Old Sep 2, 2022 | 06:16 PM
miT's Avatar
miT
Default Missing Menu Item / Wireless Headset
I have been trying to connect my wireless headset to my 22 Street Glide ST. Both the WHIM and BBGTS have the latest software/firmware and flashed enabled. My specific problem is I am missing the "Wireless Headset" menu option. I can go under settings, and scroll through the entire menu and this menu option is missing.
What I have done:
  1. I checked some older bikes and this menu option is there, but grayed out (no WHIM).
  2. Tried connecting various headsets, including Harley units through the "Bluetooth Setup" menu option with no success. This option appears to be only for connecting phones, not wireless headsets. Note, this option works fine with my phone.
Has anyone else had this problem? Any suggestions?
Tzed
Old Sep 2, 2022 | 07:09 PM
mikes300's Avatar
mikes300
did the dealer flash for the WHIM when it was installed? did it work before? mine did some weird stuff like that and it was a blown P&A fuse, no idea how that was related though.
Old Sep 2, 2022 | 08:44 PM
miT's Avatar
miT
New bike, new WHIM. Installed and flashed. From what I know, I believe the WHIM is fine. What is confusing everyone is the missing Wireless Headset menu option. I am not totally sure, but even without the WHIM, the menu option should still exist, but grayed out(?).
Old Sep 2, 2022 | 09:30 PM
golfblues's Avatar
golfblues
Check the accessory fuse....I believe its a 15 amp. My friend had the same problem and it was the fuse ss the whim gets power from the accessory fuse.
Old Sep 2, 2022 | 11:48 PM
miT's Avatar
miT
Thanks for the suggestion. I wish it were that simple (sigh). The fuse is good.
Old Sep 3, 2022 | 11:40 AM
miT's Avatar
miT
golfblues, you were spot on! I had one of the service techs at my local dealer call Harley Tech. They stated, that menu option will not appear unless the WHIM is powered, so I either have a bad WHIM and/or a bad harness. I will meter out the harness.
Old Sep 3, 2022 | 12:08 PM
golfblues's Avatar
golfblues
I'm glad to help to get it fixed. If the whim is bad or not getting power it does not show up in the the menu.... double check the fuse and make sure the whim is plugged in as it may have come loose. My friend was adding something to his audio system and when he put it back together the whim disappeared and his cooling fan did not turn on so first thing I told him was to check the accessory fuse. Bingo, he put in a new fuse and everything worked
Old Sep 3, 2022 | 12:10 PM
mikes300's Avatar
mikes300
No, it will not show up unless a whim is present and flashed for it, I suspect the dealer who installed it "did not tell the bike it had it" it must be flashed for the bike to recognize it.
Old Sep 3, 2022 | 12:29 PM
miT's Avatar
miT
Checked the PA fuse and it was good. The dealer tech unplugged and visually inspected the plug and pins. He also showed me his screen and the WHIM was enabled. All appears to be good. I am going to meter out the harness to ensure its not the harness, but I suspect it may be a bad/new WHIM module. TBD....
I really appreciate the responses.... thanks guys!
Old Sep 7, 2022 | 10:03 AM
mikes300's Avatar
mikes300
couldn't the dealer just plug in another WHIM and see if it works?
