Speaker Level Inputs
Old Sep 5, 2022 | 12:10 AM
DBGLIDE's Avatar
DBGLIDE
1st Gear
Default Speaker Level Inputs
Hoping some of you audio guru's can shed some light on this for me. I have a 21 RG and plan to do a simple upgrade for the time being. I'm planning on a Sound Digital 800.4 with the Ground Zero yellow basket coax in the fairing. I plan on using the high level inputs and wanted to know is there any problem with splitting the factory speaker lines to have one side input into ch 1 & 2 and one side input into ch 3 & 4 on the high level inputs on the amp? I didn't want to add a DSP to such a simple set up but wasn't sure if splitting the left and right speaker lines would affect the signal input to the amp.
Old Sep 5, 2022 | 10:44 AM
Fireball Jack's Avatar
Fireball Jack
You will be fine, what flash are you getting?
Old Sep 5, 2022 | 03:08 PM
DBGLIDE's Avatar
DBGLIDE
1st Gear
Thank you Fireball. From what I've read, the best flash to do is the TechnoResearch Rockford flash to get a good flat signal from the stock HU. I plan on doing the hardware part of the install myself, and then taking it to a pro shop to be sure the amp is properly tuned.
Old Sep 6, 2022 | 06:39 AM
crackalack's Avatar
crackalack
I’ve got the same question, if I use speaker pod plug adapters, do they just solder into the SD provided adapters wiring? Nothing special needed?
Old Sep 6, 2022 | 02:10 PM
DBGLIDE's Avatar
DBGLIDE
1st Gear
Looking at one of the $79 adapters I saw online for the SD amp is why I ask the question. It looks like they simply spliced the line making 2 positive and 2 negative leads from the stock speaker wire line. I'm perfectly capable of splitting 2 feed wires into 4 so I'd rather put the extra $79 to something else for my bike 😁
Old Sep 6, 2022 | 03:02 PM
Fireball Jack
It is just wires. The amp is not going to know who split them.
jtg107
Audio Systems
May 10, 2021 03:34 PM
JHC210
Audio Systems
Dec 22, 2020 06:06 PM
MikeTD3
Audio Systems
Mar 7, 2018 05:49 AM
nivensid
Jun 4, 2012 03:41 PM
1sweetglide08
Sep 20, 2011 10:51 AM
