Adding to my setup. Back downtown the rabbit hole
Old Sep 6, 2022 | 03:53 PM
dhollywood's Avatar
dhollywood
Default Adding to my setup. Back down the rabbit hole. Amp question?
Current Set-Up:
GZ Yellow Basket 6.5 Fairing and Lowers w/
(SD 1200.4 4ohm)
Diamond M075 in fairing grills and Lids w/
(SD 250)
Hertz 8” 200L in Lids w/
(SD 1200.2 2 ohm bridged)
will be moving 200L to inside bags(rear facing the wheel). And adding Hertz 8 spl show 200 neo to lids.
Do I replace 1200.2 with SD 2400.4. Or is there another suggested amp or configuration? SD 1600.1? I want to keep all amps under fairing and not in bags or a tour pack.
Old Sep 7, 2022 | 12:01 PM
Fireball Jack's Avatar
Fireball Jack
Originally Posted by dhollywood
Current Set-Up:
(SD 1200.4 4ohm)
(SD 250)
Might help if you tell the class what you are putting the amps in.
Old Sep 7, 2022 | 12:02 PM
Fireball Jack
Never mind I see you have multi thread asking the same thing!
GunslingersNation1
Audio Systems
15
Sep 1, 2019 05:14 PM
FrenchieM
Audio Systems
Jul 10, 2019 09:44 PM
pdevore
Audio Systems
25
Mar 21, 2017 10:00 AM
HOGILAC
May 13, 2014 09:23 PM
HOGILAC
May 12, 2014 02:54 PM
