I have a 21 street glide with the Sony 7000, I just purchased 4 kappa perfect 6.5s and I also have 8" subs in the bag lids running off a separate amp. I'm putting the other 2 kappas in the lowers. What amp would give me the best bang for my buck?
Will you be running the Kappas active or passive?
Will you be using a DSP to control the crossovers and frequencies between the 6.5s and 8 inch "subs" in the lids?? What amp is powering the 8s in the lids and how is it wired?
All these questions need to be answered before any recommendations. The reason is to make sure you have the proper amount of channels out of the Sony or DSP to supply the amps with the correct signal to the speakers
Just to be clear Subs work best inside the bags that have been sealed and ported to the SUB specs.
