Should I get a new head unit or….?
It’s taken me a while but I have my audio set up *pretty* good. My stats:
2015 Road glide
stock HU, stock flash
RF TM400x2ad
Biketronics 6.5” fairing speakers
Biketronics LL
The set up is loud but bright. i suck at this audio stuff but I got a few extra bucks and was wondering if I should get the Soundstream headunit. This stock Harley head is a pain to work with and I wonder if I could get more out of my system if I switched my headunit.
You can adjust the LL by backing off the hpf a bit. Look at the filter and see where the default setting is at. Now if the default is considered 12 oclock (for placement purpose) then back it off to 10 oclock and that will allow lower frequencies to play better.
Boot up time/turn on is approximately 30 seconds and connecting to the bluetooth is quick also unlike the 1.5 to 2 minutes it take for the HD GT6.5 HU.
The Sound stream has better sound quality and options out of the box with less added equipment to get it to sound good.
Considering the money some have in their audio the pricing isn't all that bad. The HU for most is the "brains" of the system.
HD 4.3/6.5GT outdated slow hardware limited functionality car play only
Sony Av5000/7000 ($700-750) has more options and better sound quality. 7 band eq Supports carplay and Android Auto but NOT water resistant
Soundstream Reserve 14+ ($860-1100)similar operating system as the Sony better Sound quality again. 13 band eq,car play & AA , water resistant.
HD GTS ($1200 -2000 used) better hardware in hu than the GT, faster boot up, but limited audio adjustments and need to be flashed
Soundstream Reserve SI ($1300- 1800). This HU has bells and whistles. It has the same features as the 14+ with the ability to display tire pressure, oil pressure, guages and control auxiliary add on systems (air ride,LEDs) when matched with the correct can bus module.
Below is a video explaining the difference more in depth
