CarPlay comes and goes
Old Jun 13, 2023 | 07:15 PM
Roadking69's Avatar
Roadking69
Default CarPlay comes and goes
I have a gts system and iPhone 13pro plug it in and it works great sometimes for 10 minutes sometimes and hour have tried a couple different cables. Any ideas
Old Jun 13, 2023 | 07:30 PM
SSSpringer's Avatar
SSSpringer
Have you tried turning off Bluetooth when plugged in? I also bought a hi performance cable rated for Android auto. Solved my issues.
Old Jun 13, 2023 | 07:51 PM
Roadking69's Avatar
Roadking69
[I have not bu but will tomorrow
QUOTE=SSSpringer;21255280]Have you tried turning off Bluetooth when plugged in? I also bought a hi performance cable rated for Android auto. Solved my issues.[/QUOTE]
Old Jun 13, 2023 | 07:58 PM
hairymoth's Avatar
hairymoth
You did not mention is you were using the plug that allows you to use CarPlay without a headset, or a headset with the WHIM; I am assuming the later because that is what likely causes the problem.
I had the same problem. This 2 part solution has worked consistently for me:
1. Unpair the headset from the phone. The phone should be paired with the infotainment system, the headset should be paired to the WHIM only. You can do everything with this configuration.
2. Always turn on the headset first, before you start the bike (or turn the ignition switch to AUX) and before you plug the phone into the USB. If CarPlay does not find the headset with mic, it will not start.
Old Jun 14, 2023 | 11:29 AM
JamesHMorris's Avatar
JamesHMorris
Stage IV
I had the same issue. Turns out it was the cable I was using. An Apple iPhone cable routed through the console so I could use a quad lock handlebar mount. I switched to a 6-inch cable and just use the built in phone holder in my Street Glide fairing. No more disconnects.
Old Jun 14, 2023 | 10:55 PM
Roadking69's Avatar
Roadking69
No radio is flashed with techno research I have tried short cables and several long ones no luck
Old Jun 15, 2023 | 01:08 AM
hamah's Avatar
hamah
I've got a 10' Amazon Basics cable running from the fairing cubby to the TP and I've got no problem. Have you tried a different iPhone?
Old Jun 16, 2023 | 06:05 AM
havinabubble's Avatar
havinabubble
Lightbulb
similar experience with Pixel 6a/Android Auto and Sony 7000 also HDHU.14 and .14si....
used to work fine, then like you 10mins!! 1hour!!! 10feet!! drove me NUTS! always ran a 6ft branded cable fine in my bike, in the car also been short branded cables. then tried short/tiny/string still no joy. made using maps impossible!
tried all the bluetooth remove/reset/hold left finger in air
finally stumbled on a suggestion to use an Anker Powerline II USB-C to USB 3.1 Gen2 Cable (3ft)
...and not had a single problem since!
I don't know what changed, but I think more data is being passed from the phones to the head-units and so the older cables are no longer good for the CP/AA job. The Anker cable is thicker, that's all I can tell ya. It worked for our 2 phones in the car and on my bike
YMMV
Old Jun 17, 2023 | 07:35 AM
cycle7447's Avatar
cycle7447
Community Influencer
That's exactly how my cable is routed. Knew my phone would not fit in the cubby - so, this way, it is in the trunk.
Old Jun 17, 2023 | 03:33 PM
hamah's Avatar
hamah
Plus this way you can still access the USB connector to plug in a USB for software updates etc.
